Trying to convert to the new PS Vita resolution of 960*544 but am not seeing a way
in the custom settings to set up that resolution? Please advise.
thanks!
PS Vita Custom resolution?
Re: PS Vita Custom resolution?
Go here
C:\Program Files\VSO\Blu-ray Converter Ultimate\custom_profiles
and place the attached file in that folder. Rename the extension to ".xml"
Use this custom profile and let us know how that works.
Go here
- PS VITA H264.txt
- (1.04 KiB) Downloaded 637 times
Thanks Claire but I'm having trouble. I clicked on your attachment and then copied everything. Then, it won't let me paste that into the custom profile folder. Are you meaning just to drag the attachment into there? Also, I'm not sure how to rename the extension, where to find that, etc?
thanks!
thanks!
maybe you do not have administrator rights.
I have no problem doing this, see the process illustrated in images
