Running 1.4.0.8 eval on W7 x64 SP1 with GTX580.
Getting Access violation in BlurayConverterUltimate.exe when entering advanced settings.
Excluded exe file from DEP but made no difference.
Wanna buy but it seems unstable...
Exception in advanced settings
Re: Exception in advanced settings
This bug is due to an old setting from older converter installation.
To fix it, open your registry editor (regedit), then delete the Blu-ray converter registry tree located on:
HKEY_CURRENT_USER\Software\VSO\Blu-ray Converter Ultimate\1.0
Restart the program, the bug should be gone.
Thank you!
Thank you!
