MP3 Codec
westnz
MP3 Codec
Post by westnz »
I'm trying to create a custom 720x576 Xvid profile, but for audio I want MP3,
how Do I get MP3 on the list of Audio Tracks Codec: ? :idea:
Blu-Ray Converter Ultimate I'm using.
Re: MP3 Codec
Maybe have you choosen a container not supporting mp3 codec as audio track?
westnz
Re: MP3 Codec
Post by westnz »
avi as container
Re: MP3 Codec
Create a custom profile and you can select your audio to be in MP3 format.
westnz
Re: MP3 Codec
Post by westnz »
that's exactly what I was trying to do.
westnz
Re: MP3 Codec
Post by westnz »
m using windows 8 consumer preview 32bit.
ive tried installing various codec packages etc and no matter what cant get mp3 listed for audio codec when trying to do a custom profile.
Re: MP3 Codec
Like we use internal decoders, installing external codec packs will not fix your problem.
Can you try by installing the last version 2 (in beta stage at this time)?
http://forums.vso-software.fr/blu-ray-c ... 15487.html
If you bought Blu-ray converter 1 for less than one year, you can get the unlock key for version 2 for free, I will send you it soon...
Thank you.
coeaeag
Re: MP3 Codec
Post by coeaeag »
Re: MP3 Codec
@ coeaeag you do not see mp3 in the custom profile section? What version are you using?
