DVD Converter Ultimate 1.4.0.8 not Converting SG-1 DVDs
dgmckenzie
Post by dgmckenzie »
Trying to rip my Stargate SG-1 DVDs to MKVs. I've done Season 10 - Season 4 and have arrived at Season 3.
I'm using: HD Ready (720p) H264 *HQ*, which should give files between 500 - 600 Mb.
I've tried Discs 5 & 2 with the same result, files around 76-104Mb and the files are unplayable, during conversion the Preview is blank.
For logging purposes I stopped the conversion once it started the second episode...
Code: Select all
2012-03-17 10:19:15	Important   	****************************************Conversion process : session end****************************************
2012-03-17 10:18:58	Info        	 Disc (DVD-ROM) not empty.
2012-03-17 10:18:56	Info        	Conversion process has been aborted by user
2012-03-17 10:16:26	Info        	Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 320.000Kb/s]
2012-03-17 10:16:26	Info        	Converting track #1 : [VIDEO: mpeg2video - 720x480] to [VIDEO: H264 - 1280x720 - 4.834Mb/s]
2012-03-17 10:16:26	Info        	Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-03-17 10:16:26	Info        	Starting to encode  Episode 2 output file with [MKV (Matroska) HD Ready (720p) H264 *HQ*] profile
2012-03-17 10:12:31	Info        	Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 320.000Kb/s]
2012-03-17 10:12:31	Info        	Converting track #1 : [VIDEO: mpeg2video - 720x480] to [VIDEO: H264 - 1280x720 - 4.834Mb/s]
2012-03-17 10:12:31	Info        	Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-03-17 10:12:31	Info        	Starting to encode  Episode 1 output file with [MKV (Matroska) HD Ready (720p) H264 *HQ*] profile
2012-03-17 10:12:31	Info        	5 files to encode
2012-03-17 10:12:31	Info        	Output folder : C:\Users\Douglas\Documents\VSODVDConverter\
2012-03-17 10:12:31	Info        	Maximum target size : 7.95 Gb.
2012-03-17 10:12:31	Info        	Video quality selected : Good quality. Resize filter used for video : Linear (VSO)
2012-03-17 10:12:31	Important   	****************************************Conversion process : session start****************************************
2012-03-17 10:12:31	Warning     	This file may have discontinuous timestamps, monotonic section parsing is recommended
2012-03-17 10:12:30	Info        	AV LOADER: File "VTS_01_0.IFO" probed format is DVD-Video Demuxer
2012-03-17 10:12:30	Warning     	This file may have discontinuous timestamps, monotonic section parsing is recommended
2012-03-17 10:12:29	Info        	AV LOADER: File "VTS_01_0.IFO" probed format is DVD-Video Demuxer
2012-03-17 10:12:29	Warning     	This file may have discontinuous timestamps, monotonic section parsing is recommended
2012-03-17 10:12:28	Info        	AV LOADER: File "VTS_01_0.IFO" probed format is DVD-Video Demuxer
2012-03-17 10:11:08	Info        	Video structure loaded successfully from:E:\VIDEO_TS\VIDEO_TS.IFO
2012-03-17 09:33:16	Info        	 Disc (DVD-ROM) not empty.
2012-03-17 09:33:15	Info        	Available Memory : 4269 Mb.
2012-03-17 09:33:15	Info        	Total Memory : 6138 Mb.
2012-03-17 09:33:15	Info        	Available extended Virtual Memory : 0 Mb.
2012-03-17 09:33:15	Info        	Available Virtual Memory : 1833 Mb.
2012-03-17 09:33:15	Info        	Total Virtual Memory : 2047 Mb.
2012-03-17 09:33:15	Info        	Memory Load  : 55%
2012-03-17 09:33:15	Info        	Available Physical Memory : 1379 Mb.
2012-03-17 09:33:15	Info        	Total Physical Memory : 3070 Mb.
2012-03-17 09:33:15	Info        	System default language : English (United Kingdom)
2012-03-17 09:33:15	Info        	User default language   : English (United Kingdom)
2012-03-17 09:33:15	Info        	Version : 1.4.0.8
2012-03-17 09:33:15	Info        	ExeName : C:\Program Files\VSO\DVD Converter Ultimate\DVDConverterUltimate.exe
2012-03-17 09:33:15	Info        	OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2012-03-17 09:33:15	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-17 09:33:15	Info        	 Drive has Serial ATA physical interface
2012-03-17 09:33:15	Info        	 New Drive selected : 1:0:0 - PLDS DVD+-RW DH-16AAS JD12 [E] (Ide)
2012-03-17 09:33:15	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-03-17 09:33:15	Info        	 New Drive selected : 2:0:0 - HL-DT-ST BD-RE  BH10LS30 1.01 [F] (Ide)
2012-03-17 09:33:14	Info        	 Using Advanced SPTI interface
2012-03-17 09:33:13	----        	******************** Log session start 17-Mar 09:33:13.834 PID 4700********************
I can convert using MakeMKV which gives files around 1.5GB and Handbrake which gives me files of the size and quality (?) that I want.
Douglas
Re: DVD Converter Ultimate 1.4.0.8 not Converting SG-1 DVDs
Can you play the videos with a video player on your computer before trying to convert them? What is the video player?
Are you using a decryptor?
dgmckenzie
Hi Clare
Season 3 is Region 1 (some of the other Seasons were also Region 1).
I'm using the latest AnyDVD HD to frig the Region.
I can play the discs with:
* PowerDVD 9
* Windows Media Player
* VSO Media Player 0.1.1.268
* VLC Media Player 2.0.0.0
Can you read it with the latest version of VSO Media Player?
dgmckenzie
Hi Clare
Installed Vso Media Player - Version 1.0.0.422 :cry:
Loaded DVD 1 and let AnyDVD HD chug away.
When I told VMP where to find the DVD structure it gave me the following message:
This disc may be protected.
If you experience troubles at playback you may need a decryptor such as AnyDVD
And when I selected the first episode, it flashed up "Please Wait" and moved on to the next Episode and on through the Bonus items without playing anything :(
Douglas
So the conversion did finish successfully but the files were too small and unplayable?
dgmckenzie
Yes
Can you please try with the new version 2.0.0.4
http://forums.vso-software.fr/dvd-converter-t14598.html
dgmckenzie
Hi Clare
Downloaded v2.0.0.4 and I am running in Trial Mode as I can't receive the new key for some reason.
I'm using MKV (Matroska) HD Ready (720p) H264 which has given a file 1,014,978 for Episode 1 of Season 3. It took about 30 minutes to transcode the 10 minutes. The small thumb showed throughout.
But it is not watchable. Diagonal lines and every so often a normal viewable picture for less than a second.
Left picture is MKV, right picture is the Source DVD playing in sync.
And the log
Code: Select all
2012-03-29 17:39:40	Info        	9 Menu templates loaded.
2012-03-29 17:39:37	Info        	9 Menu templates loaded.
2012-03-29 17:39:36	Info        	 Disc (DVD-ROM) not empty.
2012-03-29 17:39:35	Info        	Available Memory : 4247 Mb.
2012-03-29 17:39:35	Info        	Total Memory : 6138 Mb.
2012-03-29 17:39:35	Info        	Available extended Virtual Memory : 0 Mb.
2012-03-29 17:39:35	Info        	Available Virtual Memory : 1855 Mb.
2012-03-29 17:39:35	Info        	Total Virtual Memory : 2047 Mb.
2012-03-29 17:39:35	Info        	Memory Load  : 52%
2012-03-29 17:39:35	Info        	Available Physical Memory : 1469 Mb.
2012-03-29 17:39:35	Info        	Total Physical Memory : 3070 Mb.
2012-03-29 17:39:35	Info        	System default language : English (United Kingdom)
2012-03-29 17:39:35	Info        	User default language   : English (United Kingdom)
2012-03-29 17:39:35	Info        	Version : 2.0.0.4
2012-03-29 17:39:35	Info        	ExeName : C:\Program Files\VSO\DVD Converter Ultimate\2\DVDConverterUltimate.exe
2012-03-29 17:39:35	Info        	OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2012-03-29 17:39:35	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-29 17:39:35	Info        	 Drive has Serial ATA physical interface
2012-03-29 17:39:35	Info        	 New Drive selected : 1:0:0 - PLDS DVD+-RW DH-16AAS JD12 [E] (Ide)
2012-03-29 17:39:35	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-03-29 17:39:35	Info        	 New Drive selected : 2:0:0 - HL-DT-ST BD-RE  BH10LS30 1.01 [F] (Ide)
2012-03-29 17:39:34	Info        	 Using Advanced SPTI interface
2012-03-29 17:39:34	----        	******************** Log session start 29-Mar 17:39:34.225 PID 6860********************
2012-03-29 17:31:22	----        	******************** Log session stop  29-Mar 17:31:22.867 PID 3696********************
2012-03-29 17:29:16	Info        	Conversion process completed successfully
2012-03-29 16:52:42	Info        	Converted project will be burnt using E: drive
2012-03-29 16:52:42	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-29 16:52:42	Info        	 Drive has Serial ATA physical interface
2012-03-29 16:52:42	Info        	 New Drive selected : 1:0:0 - PLDS DVD+-RW DH-16AAS JD12 [E] (Ide)
2012-03-29 16:52:15	Info        	 Disc (DVD-ROM) not empty.
2012-03-29 16:52:15	Info        	Video structure loaded successfully from:E:\VIDEO_TS\VIDEO_TS.IFO
2012-03-29 16:46:53	Info        	9 Menu templates loaded.
2012-03-29 16:44:25	Info        	9 Menu templates loaded.
2012-03-29 16:44:24	Info        	 Disc (DVD-ROM) not empty.
2012-03-29 16:44:22	Info        	Available Memory : 4334 Mb.
2012-03-29 16:44:22	Info        	Total Memory : 6138 Mb.
2012-03-29 16:44:22	Info        	Available extended Virtual Memory : 0 Mb.
2012-03-29 16:44:22	Info        	Available Virtual Memory : 1863 Mb.
2012-03-29 16:44:22	Info        	Total Virtual Memory : 2047 Mb.
2012-03-29 16:44:22	Info        	Memory Load  : 51%
2012-03-29 16:44:22	Info        	Available Physical Memory : 1485 Mb.
2012-03-29 16:44:22	Info        	Total Physical Memory : 3070 Mb.
2012-03-29 16:44:22	Info        	System default language : English (United Kingdom)
2012-03-29 16:44:22	Info        	User default language   : English (United Kingdom)
2012-03-29 16:44:22	Info        	Version : 2.0.0.4
2012-03-29 16:44:22	Info        	ExeName : C:\Program Files\vso\DVD Converter Ultimate\2\DVDConverterUltimate.exe
2012-03-29 16:44:22	Info        	OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2012-03-29 16:44:22	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-29 16:44:22	Info        	 Drive has Serial ATA physical interface
2012-03-29 16:44:22	Info        	 New Drive selected : 1:0:0 - PLDS DVD+-RW DH-16AAS JD12 [E] (Ide)
2012-03-29 16:44:22	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-03-29 16:44:22	Info        	 New Drive selected : 2:0:0 - HL-DT-ST BD-RE  BH10LS30 1.01 [F] (Ide)
2012-03-29 16:44:20	Info        	 Using Advanced SPTI interface
2012-03-29 16:44:16	----        	******************** Log session start 29-Mar 16:44:16.882 PID 3696********************
Douglas
To me it looks like protection issue. Very many series are released with different protections on same DVD set.
dgmckenzie
But they can and were ripped by Handbrake, just not by DVD Converter and they could not be played using the latest VSO Media Player.
Try ripping those discs to harddrive, then check size of ripped folder and try play that folder.
If result is clean and playable, then convert that folder.
It might be that AnyDVD HD can't remove protection fully from those DVDs...
Trying what JJ suggests would help.
As for your key, you can PM me you first and last name and or email address and I will send you the new key.
dgmckenzie
<sigh>
* Copied disk 2 this time using AnyDVD to Folder
* Played the folder using VLC 2.0.0.0 - Ok
* Tried folder using Vso Media Player - "Warning - This disc may be protected."
* Played folder using CyberLink PowerDVD 9 - Ok
Used DVD Converter with the same result and no change to the log file e.g nothing about 'bad' files like the older version.
So no change copying the files to the Harddrive.
Douglas
PS. I'm not going to be available (on the internet) for the next week.
dgmckenzie
Ran the copied files through CloneDVD and created and ISO.
Vso Media Play gives the same Warning trying to play the new ISO/UDF Image
This might be it. Protected files can often be played fine, but not converted.
