I may be mis-remembering, but I thought an earlier version of VMP (beta?), if given a playlist, would start at the beginning and play through without intervention, and stop at the end.
It seems that the current version (1.0.1.422 per the website - although the player reports that it's 1.0.0.422, but that's another issue) plays the currently-selected video and stops. Even if I select all videos with ctl-A and choose "play from start", it stops at the end of the first video. I tried the loop control and it didn't help either.
I'm not sure if this is a bug, or I'm doing something wrong, or mis-remembering. At any rate, I'd like to be able to run three videos back-to-back without intervention, and then stop at the end of the playlist. Can anyone help me out ?
Thanks, Doug
VMP auto-play through playlist, and version issue
Re: VMP auto-play through playlist, and version issue
Here is the logfile. Note that I uninstalled/reinstalled because of the mistake in version number in program vs on website,
You will probably want to skip down a bit.
Thanks Doug
2012-04-15 16:09:35 Info Removed line: "C:\Program Files\VSO\VSO Media Player\1\VMP.exe"
2012-04-15 16:09:35 Info Executing command line: "C:\Program Files\VSO\VSO Media Player\1\VMP.exe"
2012-04-15 16:09:35 Info Raw command line: ""C:\Program Files\VSO\VSO Media Player\1\VMP.exe""
2012-04-15 16:09:33 Info Program started
2012-04-15 16:09:33 Info Available Memory : 6235 Mb.
2012-04-15 16:09:33 Info Total Memory : 7574 Mb.
2012-04-15 16:09:33 Info Available extended Virtual Memory : 0 Mb.
2012-04-15 16:09:33 Info Available Virtual Memory : 1871 Mb.
2012-04-15 16:09:33 Info Total Virtual Memory : 2047 Mb.
2012-04-15 16:09:33 Info Memory Load : 49%
2012-04-15 16:09:33 Info Available Physical Memory : 1552 Mb.
2012-04-15 16:09:33 Info Total Physical Memory : 3069 Mb.
2012-04-15 16:09:33 Info System default language : English (United States)
2012-04-15 16:09:33 Info User default language : English (United States)
2012-04-15 16:09:33 Info Version : 1.0.0.422
2012-04-15 16:09:33 Info ExeName : C:\Program Files\VSO\VSO Media Player\1\VMP.exe
2012-04-15 16:09:33 Info OS : Microsoft Windows Vista Home Premium (Build 6002: Service Pack 2)
2012-04-15 16:09:33 Verbose Configuration - UseCudaDecoder: 0
2012-04-15 16:09:33 Verbose Configuration - AppVersion: 1.0.0.422
2012-04-15 16:09:33 Verbose Configuration - Volume: 61
2012-04-15 16:09:33 Verbose Configuration - VolumeStep: 5
2012-04-15 16:09:33 Verbose Configuration - StartFullScreen: 0
2012-04-15 16:09:33 Verbose Configuration - SeekStep: 10
2012-04-15 16:09:33 Verbose Configuration - ScaleMode: 2
2012-04-15 16:09:33 Verbose Configuration - Saturation: 1
2012-04-15 16:09:33 Verbose Configuration - UseMultiProcessor: 1
2012-04-15 16:09:33 Verbose Configuration - UseGdi: 1
2012-04-15 16:09:33 Verbose Configuration - UiOpacity: 230
2012-04-15 16:09:33 Verbose Configuration - UiMode: 0
2012-04-15 16:09:33 Verbose Configuration - RollOutThreshold: 10
2012-04-15 16:09:33 Verbose Configuration - RememberLastOpenedFiles: 0
2012-04-15 16:09:33 Verbose Configuration - PreferedSttLanguage:
2012-04-15 16:09:33 Verbose Configuration - PreferedAudioLanguage: en
2012-04-15 16:09:33 Verbose Configuration - PanelTimeHeight: 76
2012-04-15 16:09:33 Verbose Configuration - MouseWheelControls: 0
2012-04-15 16:09:33 Verbose Configuration - LastVideoStructurePath:
2012-04-15 16:09:33 Verbose Configuration - LastVideoFilePath: C:\Users\Public\Videos\ASCC_Videos\
2012-04-15 16:09:33 Verbose Configuration - LastPgFilePath:
2012-04-15 16:09:33 Verbose Configuration - LastPlaylistPath: C:\Users\ASCC_Video\Documents\VSO Media Player\
2012-04-15 16:09:33 Verbose Configuration - LastAudioFilePath: C:\Users\Public\Videos\ASCC_Videos\
2012-04-15 16:09:33 Verbose Configuration - Gamma: 1
2012-04-15 16:09:33 Verbose Configuration - FrmWidth: 800
2012-04-15 16:09:33 Verbose Configuration - FrmTop: 28
2012-04-15 16:09:33 Verbose Configuration - FrmLeft: 439
2012-04-15 16:09:33 Verbose Configuration - FrmHeight: 565
2012-04-15 16:09:33 Verbose Configuration - FadeStayTime: 2
2012-04-15 16:09:33 Verbose Configuration - EndAction: 0
2012-04-15 16:09:33 Verbose Configuration - Contrast: 1
2012-04-15 16:09:33 Verbose Configuration - Brightness: 0
2012-04-15 16:09:33 Verbose Configuration - BackupSttLanguage:
2012-04-15 16:09:33 Verbose Configuration - BackupAudioLanguage: en
2012-04-15 16:09:33 Verbose Configuration - BackGroundColor: -16777201
2012-04-15 16:09:33 Verbose Configuration - AutoPinSideBar: 0
2012-04-15 16:09:33 Verbose Configuration - AutoResumeCount: -1
2012-04-15 16:09:33 Verbose Configuration - AutoResumeMode: 1
2012-04-15 16:09:33 Verbose Configuration - AudioChannelMode: 0
2012-04-15 16:09:33 Verbose Configuration - AnimationSpeed: 200
2012-04-15 16:09:33 Verbose Configuration - AllowMultipleInstances: 0
2012-04-15 16:09:33 Verbose Configuration - OnWritableMediaRequired_EventFile: C:\Program Files\VSO\Common\Sounds\OnWritableMediaRequired_0409.ogg
2012-04-15 16:09:33 Verbose Configuration - OnQuestion_EventFile: C:\Program Files\VSO\Common\Sounds\OnQuestion_0409.ogg
2012-04-15 16:09:33 Verbose Configuration - OnProblem_EventFile: C:\Program Files\VSO\Common\Sounds\OnProblemDetected_0409.ogg
2012-04-15 16:09:33 Verbose Configuration - OnOperationComplete_EventFile: C:\Program Files\VSO\Common\Sounds\OnOperationComplete_0409.ogg
2012-04-15 16:09:33 Verbose Configuration - OnNewVersion_EventFile: C:\Program Files\VSO\Common\Sounds\OnNewVersion_0409.ogg
2012-04-15 16:09:33 Verbose Configuration - PlaySoundEvents: 0
2012-04-15 16:09:33 Info Supported instruction set: sse3
2012-04-15 16:09:33 Info Maximum number of threads detected: 2 - parallelize up to 2
2012-04-15 16:09:33 Info Tuning Performances for Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz with 2 core(s) CPU
2012-04-15 16:09:33 ---- ******************** Log session start 15-Apr 16:09:33.320 PID 6012********************
2012-04-15 16:07:26 ---- ******************** Log session stop 15-Apr 16:07:26.406 PID 5572********************
2012-04-15 16:00:27 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Sacrifice of Praise medley.flv'
2012-04-15 16:00:27 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:07:33
2012-04-15 16:00:27 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:07:33
2012-04-15 16:00:27 Info AV LOADER: File "Sacrifice of Praise medley.flv" probed format is FLV format
2012-04-15 15:52:53 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Victory chant.flv'
2012-04-15 15:52:53 Info Stream #1 - aac main audio, 44100 kHz, Stereo, 114 kbps started at 0:02:54
2012-04-15 15:52:53 Info Stream #0 - h264 video, 320x240, YUV420P, 1.00 started at 0:02:54
2012-04-15 15:52:53 Info AV LOADER: File "Victory chant.flv" probed format is FLV format
2012-04-15 15:48:54 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Sacrifice of Praise medley.flv'
2012-04-15 15:48:54 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:00:02
2012-04-15 15:48:54 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:00:02
2012-04-15 15:48:54 Info AV LOADER: File "Sacrifice of Praise medley.flv" probed format is FLV format
2012-04-15 15:48:51 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Victory chant.flv'
2012-04-15 15:48:51 Info Stream #1 - aac main audio, 44100 kHz, Stereo, 114 kbps started at 0:00:00
2012-04-15 15:48:51 Info Stream #0 - h264 video, 320x240, YUV420P, 1.00 started at 0:00:00
2012-04-15 15:48:51 Info AV LOADER: File "Victory chant.flv" probed format is FLV format
2012-04-15 15:40:39 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Sacrifice of Praise medley.flv'
2012-04-15 15:40:39 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:00:06
2012-04-15 15:40:39 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:00:06
2012-04-15 15:40:39 Info AV LOADER: File "Sacrifice of Praise medley.flv" probed format is FLV format
2012-04-15 15:40:31 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Victory chant.flv'
2012-04-15 15:40:31 Info Stream #1 - aac main audio, 44100 kHz, Stereo, 114 kbps started at 0:00:04
2012-04-15 15:40:31 Info Stream #0 - h264 video, 320x240, YUV420P, 1.00 started at 0:00:04
2012-04-15 15:40:31 Info AV LOADER: File "Victory chant.flv" probed format is FLV format
2012-04-15 15:40:26 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Sacrifice of Praise medley.flv'
2012-04-15 15:40:26 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:00:00
2012-04-15 15:40:26 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:00:00
2012-04-15 15:40:26 Info AV LOADER: File "Sacrifice of Praise medley.flv" probed format is FLV format
2012-04-15 15:38:39 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Come, Now is the Time to Worship.flv'
2012-04-15 15:38:39 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:06:52
2012-04-15 15:38:39 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:06:52
2012-04-15 15:38:39 Info AV LOADER: File "Come, Now is the Time to Worship.flv" probed format is FLV format
2012-04-15 14:56:02 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Agnus Dei - Michael W. Smith.flv'
2012-04-15 14:56:02 Info Stream #1 - aac main audio, 44100 kHz, Stereo, 111 kbps started at 0:00:00
2012-04-15 14:56:02 Info Stream #0 - h264 video, 640x480, YUV420P, 1.00 started at 0:00:00
2012-04-15 14:56:02 Info AV LOADER: File "Agnus Dei - Michael W. Smith.flv" probed format is FLV format
2012-04-15 14:55:35 Info Raw command line: ""C:\Program Files\VSO\VSO Media Player\1\VMP.exe" "
2012-04-15 14:55:34 Info Program started
2012-04-15 14:55:34 Info Available Memory : 6294 Mb.
2012-04-15 14:55:34 Info Total Memory : 7574 Mb.
2012-04-15 14:55:34 Info Available extended Virtual Memory : 0 Mb.
2012-04-15 14:55:34 Info Available Virtual Memory : 1871 Mb.
2012-04-15 14:55:34 Info Total Virtual Memory : 2047 Mb.
2012-04-15 14:55:34 Info Memory Load : 47%
2012-04-15 14:55:34 Info Available Physical Memory : 1600 Mb.
2012-04-15 14:55:34 Info Total Physical Memory : 3069 Mb.
2012-04-15 14:55:34 Info System default language : English (United States)
2012-04-15 14:55:34 Info User default language : English (United States)
2012-04-15 14:55:34 Info Version : 1.0.0.422
2012-04-15 14:55:34 Info ExeName : C:\Program Files\VSO\VSO Media Player\1\VMP.exe
2012-04-15 14:55:34 Info OS : Microsoft Windows Vista Home Premium (Build 6002: Service Pack 2)
2012-04-15 14:55:34 Verbose Configuration - UseCudaDecoder: 0
2012-04-15 14:55:34 Verbose Configuration - AppVersion: 1.0.0.422
2012-04-15 14:55:34 Verbose Configuration - Volume: 100
2012-04-15 14:55:34 Verbose Configuration - VolumeStep: 5
2012-04-15 14:55:34 Verbose Configuration - StartFullScreen: 0
2012-04-15 14:55:34 Verbose Configuration - SeekStep: 10
2012-04-15 14:55:34 Verbose Configuration - ScaleMode: 2
2012-04-15 14:55:34 Verbose Configuration - Saturation: 1
2012-04-15 14:55:34 Verbose Configuration - UseMultiProcessor: 1
2012-04-15 14:55:34 Verbose Configuration - UseGdi: 1
2012-04-15 14:55:34 Verbose Configuration - UiOpacity: 230
2012-04-15 14:55:34 Verbose Configuration - UiMode: 0
2012-04-15 14:55:34 Verbose Configuration - RollOutThreshold: 10
2012-04-15 14:55:34 Verbose Configuration - RememberLastOpenedFiles: 0
2012-04-15 14:55:34 Verbose Configuration - PreferedSttLanguage:
2012-04-15 14:55:34 Verbose Configuration - PreferedAudioLanguage: en
2012-04-15 14:55:34 Verbose Configuration - PanelTimeHeight: 76
2012-04-15 14:55:34 Verbose Configuration - MouseWheelControls: 0
2012-04-15 14:55:34 Verbose Configuration - LastVideoStructurePath:
2012-04-15 14:55:34 Verbose Configuration - LastVideoFilePath:
2012-04-15 14:55:34 Verbose Configuration - LastPgFilePath:
2012-04-15 14:55:34 Verbose Configuration - LastPlaylistPath:
2012-04-15 14:55:34 Verbose Configuration - LastAudioFilePath:
2012-04-15 14:55:34 Verbose Configuration - Gamma: 1
2012-04-15 14:55:34 Verbose Configuration - FrmWidth: 800
2012-04-15 14:55:34 Verbose Configuration - FrmTop: 15
2012-04-15 14:55:34 Verbose Configuration - FrmLeft: 331
2012-04-15 14:55:34 Verbose Configuration - FrmHeight: 565
2012-04-15 14:55:34 Verbose Configuration - FadeStayTime: 2
2012-04-15 14:55:34 Verbose Configuration - EndAction: 0
2012-04-15 14:55:34 Verbose Configuration - Contrast: 1
2012-04-15 14:55:34 Verbose Configuration - Brightness: 0
2012-04-15 14:55:34 Verbose Configuration - BackupSttLanguage:
2012-04-15 14:55:34 Verbose Configuration - BackupAudioLanguage: en
2012-04-15 14:55:34 Verbose Configuration - BackGroundColor: -16777201
2012-04-15 14:55:34 Verbose Configuration - AutoPinSideBar: 0
2012-04-15 14:55:34 Verbose Configuration - AutoResumeCount: -1
2012-04-15 14:55:34 Verbose Configuration - AutoResumeMode: 1
2012-04-15 14:55:34 Verbose Configuration - AudioChannelMode: 0
2012-04-15 14:55:34 Verbose Configuration - AnimationSpeed: 200
2012-04-15 14:55:34 Verbose Configuration - AllowMultipleInstances: 0
2012-04-15 14:55:34 Verbose Configuration - OnWritableMediaRequired_EventFile: C:\Program Files\VSO\Common\Sounds\OnWritableMediaRequired_0409.ogg
2012-04-15 14:55:34 Verbose Configuration - OnQuestion_EventFile: C:\Program Files\VSO\Common\Sounds\OnQuestion_0409.ogg
2012-04-15 14:55:34 Verbose Configuration - OnProblem_EventFile: C:\Program Files\VSO\Common\Sounds\OnProblemDetected_0409.ogg
2012-04-15 14:55:34 Verbose Configuration - OnOperationComplete_EventFile: C:\Program Files\VSO\Common\Sounds\OnOperationComplete_0409.ogg
2012-04-15 14:55:34 Verbose Configuration - OnNewVersion_EventFile: C:\Program Files\VSO\Common\Sounds\OnNewVersion_0409.ogg
2012-04-15 14:55:34 Verbose Configuration - PlaySoundEvents: 0
2012-04-15 14:55:33 Info Supported instruction set: sse3
2012-04-15 14:55:33 Info Maximum number of threads detected: 2 - parallelize up to 2
2012-04-15 14:55:33 Info Tuning Performances for Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz with 2 core(s) CPU
2012-04-15 14:55:33 ---- ******************** Log session start 15-Apr 14:55:33.583 PID 5572********************
2012-04-15 14:39:11 ---- ******************** Log session stop 15-Apr 14:39:11.202 PID 5472********************
2012-04-15 14:36:49 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Come, Now is the Time to Worship.flv'
2012-04-15 14:36:49 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:00:00
2012-04-15 14:36:49 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:00:00
2012-04-15 14:36:48 Info AV LOADER: File "Come, Now is the Time to Worship.flv" probed format is FLV format
2012-04-15 14:32:52 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Agnus Dei - Michael W. Smith.flv'
2012-04-15 14:32:52 Info Stream #1 - aac main audio, 44100 kHz, Stereo, 111 kbps started at 0:00:00
2012-04-15 14:32:52 Info Stream #0 - h264 video, 640x480, YUV420P, 1.00 started at 0:00:00
2012-04-15 14:32:52 Info AV LOADER: File "Agnus Dei - Michael W. Smith.flv" probed format is FLV format
2012-04-15 14:28:53 Info Raw command line: ""C:\Program Files\VSO\VSO Media Player\1\VMP.exe" "
2012-04-15 14:28:51 Info Program started
2012-04-15 14:28:51 Info Available Memory : 6248 Mb.
2012-04-15 14:28:51 Info Total Memory : 7574 Mb.
2012-04-15 14:28:51 Info Available extended Virtual Memory : 0 Mb.
2012-04-15 14:28:51 Info Available Virtual Memory : 1872 Mb.
2012-04-15 14:28:51 Info Total Virtual Memory : 2047 Mb.
2012-04-15 14:28:51 Info Memory Load : 49%
2012-04-15 14:28:51 Info Available Physical Memory : 1552 Mb.
2012-04-15 14:28:51 Info Total Physical Memory : 3069 Mb.
2012-04-15 14:28:51 Info System default language : English (United States)
2012-04-15 14:28:51 Info User default language : English (United States)
2012-04-15 14:28:51 Info Version : 1.0.0.422
2012-04-15 14:28:51 Info ExeName : C:\Program Files\VSO\VSO Media Player\1\VMP.exe
2012-04-15 14:28:51 Info OS : Microsoft Windows Vista Home Premium (Build 6002: Service Pack 2)
2012-04-15 14:28:51 Verbose Configuration - UseCudaDecoder: 0
2012-04-15 14:28:51 Verbose Configuration - AppVersion: 1.0.0.422
2012-04-15 14:28:51 Verbose Configuration - Volume: 100
2012-04-15 14:28:51 Verbose Configuration - VolumeStep: 5
2012-04-15 14:28:51 Verbose Configuration - StartFullScreen: 0
2012-04-15 14:28:51 Verbose Configuration - SeekStep: 10
2012-04-15 14:28:51 Verbose Configuration - ScaleMode: 2
2012-04-15 14:28:51 Verbose Configuration - Saturation: 1
2012-04-15 14:28:51 Verbose Configuration - UseMultiProcessor: 1
2012-04-15 14:28:51 Verbose Configuration - UseGdi: 1
2012-04-15 14:28:51 Verbose Configuration - UiOpacity: 230
2012-04-15 14:28:51 Verbose Configuration - UiMode: 0
2012-04-15 14:28:51 Verbose Configuration - RollOutThreshold: 10
2012-04-15 14:28:51 Verbose Configuration - RememberLastOpenedFiles: 0
2012-04-15 14:28:51 Verbose Configuration - PreferedSttLanguage:
2012-04-15 14:28:51 Verbose Configuration - PreferedAudioLanguage: en
2012-04-15 14:28:51 Verbose Configuration - PanelTimeHeight: 76
2012-04-15 14:28:51 Verbose Configuration - MouseWheelControls: 0
2012-04-15 14:28:51 Verbose Configuration - LastVideoStructurePath:
2012-04-15 14:28:51 Verbose Configuration - LastVideoFilePath:
2012-04-15 14:28:51 Verbose Configuration - LastPgFilePath:
2012-04-15 14:28:51 Verbose Configuration - LastPlaylistPath:
2012-04-15 14:28:51 Verbose Configuration - LastAudioFilePath:
2012-04-15 14:28:51 Verbose Configuration - Gamma: 1
2012-04-15 14:28:51 Verbose Configuration - FrmWidth: 800
2012-04-15 14:28:51 Verbose Configuration - FrmTop: 118
2012-04-15 14:28:51 Verbose Configuration - FrmLeft: 240
2012-04-15 14:28:51 Verbose Configuration - FrmHeight: 565
2012-04-15 14:28:51 Verbose Configuration - FadeStayTime: 2
2012-04-15 14:28:51 Verbose Configuration - EndAction: 0
2012-04-15 14:28:51 Verbose Configuration - Contrast: 1
2012-04-15 14:28:51 Verbose Configuration - Brightness: 0
2012-04-15 14:28:51 Verbose Configuration - BackupSttLanguage:
2012-04-15 14:28:51 Verbose Configuration - BackupAudioLanguage: en
2012-04-15 14:28:51 Verbose Configuration - BackGroundColor: -16777201
2012-04-15 14:28:51 Verbose Configuration - AutoPinSideBar: 0
2012-04-15 14:28:51 Verbose Configuration - AutoResumeCount: -1
2012-04-15 14:28:51 Verbose Configuration - AutoResumeMode: 1
2012-04-15 14:28:51 Verbose Configuration - AudioChannelMode: 0
2012-04-15 14:28:51 Verbose Configuration - AnimationSpeed: 200
2012-04-15 14:28:51 Verbose Configuration - AllowMultipleInstances: 0
2012-04-15 14:28:51 Verbose Configuration - OnWritableMediaRequired_EventFile: C:\Program Files\VSO\Common\Sounds\OnWritableMediaRequired_0409.ogg
2012-04-15 14:28:51 Verbose Configuration - OnQuestion_EventFile: C:\Program Files\VSO\Common\Sounds\OnQuestion_0409.ogg
2012-04-15 14:28:51 Verbose Configuration - OnProblem_EventFile: C:\Program Files\VSO\Common\Sounds\OnProblemDetected_0409.ogg
2012-04-15 14:28:51 Verbose Configuration - OnOperationComplete_EventFile: C:\Program Files\VSO\Common\Sounds\OnOperationComplete_0409.ogg
2012-04-15 14:28:51 Verbose Configuration - OnNewVersion_EventFile: C:\Program Files\VSO\Common\Sounds\OnNewVersion_0409.ogg
2012-04-15 14:28:51 Verbose Configuration - PlaySoundEvents: 0
2012-04-15 14:28:51 Info Supported instruction set: sse3
2012-04-15 14:28:51 Info Maximum number of threads detected: 2 - parallelize up to 2
2012-04-15 14:28:51 Info Tuning Performances for Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz with 2 core(s) CPU
2012-04-15 14:28:50 ---- ******************** Log session start 15-Apr 14:28:50.438 PID 5472********************
2012-04-15 08:59:59 ---- ******************** Log session stop 15-Apr 08:59:59.207 PID 5648********************
2012-04-15 08:58:39 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Rise Up and Praise Him - Women of Faith.flv'
2012-04-15 08:58:38 Info Stream #1 - mp3 main audio, 44100 kHz, 2 Ch., 128 kbps started at 0:00:05
2012-04-15 08:58:38 Info Stream #0 - vp6f video, 640x480, YUV420P started at 0:00:05
2012-04-15 08:58:38 Info AV LOADER: File "Rise Up and Praise Him - Women of Faith.flv" probed format is FLV format
2012-04-15 08:58:31 Info Playing file: 'C:\Users\Public\Videos\ASCC_Videos\Agnus Dei - Michael W. Smith.flv'
2012-04-15 08:58:31 Info Stream #1 - aac main audio, 44100 kHz, Stereo, 111 kbps started at 0:00:00
2012-04-15 08:58:31 Info Stream #0 - h264 video, 640x480, YUV420P, 1.00 started at 0:00:00
2012-04-15 08:58:31 Info AV LOADER: File "Agnus Dei - Michael W. Smith.flv" probed format is FLV format
2012-04-15 08:58:30 Info Added line: "C:\Users\Public\Videos\ASCC_Videos\Agnus Dei - Michael W. Smith.flv"
2012-04-15 08:58:30 Info Executing command line: "C:\Users\Public\Videos\ASCC_Videos\Agnus Dei - Michael W. Smith.flv"
2012-04-15 08:58:30 Info Raw command line: ""C:\Program Files\VSO\VSO Media Player\1\VMP.exe" "C:\Users\Public\Videos\ASCC_Videos\Agnus Dei - Michael W. Smith.flv""
2012-04-15 08:58:28 Info Program started
2012-04-15 08:58:28 Info Available Memory : 6134 Mb.
2012-04-15 08:58:28 Info Total Memory : 7574 Mb.
2012-04-15 08:58:28 Info Available extended Virtual Memory : 0 Mb.
2012-04-15 08:58:28 Info Available Virtual Memory : 1851 Mb.
2012-04-15 08:58:28 Info Total Virtual Memory : 2047 Mb.
2012-04-15 08:58:28 Info Memory Load : 55%
2012-04-15 08:58:28 Info Available Physical Memory : 1378 Mb.
2012-04-15 08:58:28 Info Total Physical Memory : 3069 Mb.
2012-04-15 08:58:28 Info System default language : English (United States)
2012-04-15 08:58:28 Info User default language : English (United States)
2012-04-15 08:58:28 Info Version : 1.0.0.422
2012-04-15 08:58:28 Info ExeName : C:\Program Files\VSO\VSO Media Player\1\VMP.exe
2012-04-15 08:58:28 Info OS : Microsoft Windows Vista Home Premium (Build 6002: Service Pack 2)
2012-04-15 08:58:28 Verbose Configuration - UseCudaDecoder: 0
2012-04-15 08:58:28 Verbose Configuration - AppVersion: 1.0.0.422
2012-04-15 08:58:28 Verbose Configuration - Volume: 32767
2012-04-15 08:58:28 Verbose Configuration - VolumeStep: 5
2012-04-15 08:58:28 Verbose Configuration - StartFullScreen: 0
2012-04-15 08:58:28 Verbose Configuration - SeekStep: 10
2012-04-15 08:58:28 Verbose Configuration - ScaleMode: 2
2012-04-15 08:58:28 Verbose Configuration - Saturation: 1
2012-04-15 08:58:28 Verbose Configuration - UseMultiProcessor: 1
2012-04-15 08:58:28 Verbose Configuration - UseGdi: 1
2012-04-15 08:58:28 Verbose Configuration - UiOpacity: 230
2012-04-15 08:58:28 Verbose Configuration - UiMode: 0
2012-04-15 08:58:28 Verbose Configuration - RollOutThreshold: 10
2012-04-15 08:58:28 Verbose Configuration - RememberLastOpenedFiles: 0
2012-04-15 08:58:28 Verbose Configuration - PreferedSttLanguage:
2012-04-15 08:58:28 Verbose Configuration - PreferedAudioLanguage: en
2012-04-15 08:58:28 Verbose Configuration - PanelTimeHeight: 30
2012-04-15 08:58:28 Verbose Configuration - MouseWheelControls: 0
2012-04-15 08:58:28 Verbose Configuration - LastVideoStructurePath:
2012-04-15 08:58:28 Verbose Configuration - LastVideoFilePath:
2012-04-15 08:58:28 Verbose Configuration - LastPgFilePath:
2012-04-15 08:58:28 Verbose Configuration - LastPlaylistPath:
2012-04-15 08:58:28 Verbose Configuration - LastAudioFilePath:
2012-04-15 08:58:28 Verbose Configuration - Gamma: 1
2012-04-15 08:58:28 Verbose Configuration - FrmWidth: 681
2012-04-15 08:58:28 Verbose Configuration - FrmTop: -1
2012-04-15 08:58:28 Verbose Configuration - FrmLeft: -1
2012-04-15 08:58:28 Verbose Configuration - FrmHeight: 419
2012-04-15 08:58:28 Verbose Configuration - FadeStayTime: 2
2012-04-15 08:58:28 Verbose Configuration - EndAction: 0
2012-04-15 08:58:28 Verbose Configuration - Contrast: 1
2012-04-15 08:58:28 Verbose Configuration - Brightness: 0
2012-04-15 08:58:28 Verbose Configuration - BackupSttLanguage:
2012-04-15 08:58:28 Verbose Configuration - BackupAudioLanguage: en
2012-04-15 08:58:28 Verbose Configuration - BackGroundColor: -16777201
2012-04-15 08:58:28 Verbose Configuration - AutoPinSideBar: 0
2012-04-15 08:58:28 Verbose Configuration - AutoResumeCount: -1
2012-04-15 08:58:28 Verbose Configuration - AutoResumeMode: 1
2012-04-15 08:58:28 Verbose Configuration - AudioChannelMode: 0
2012-04-15 08:58:28 Verbose Configuration - AnimationSpeed: 200
2012-04-15 08:58:28 Verbose Configuration - AllowMultipleInstances: 0
2012-04-15 08:58:28 Verbose Configuration - OnWritableMediaRequired_EventFile: C:\Program Files\VSO\Common\Sounds\OnWritableMediaRequired_0409.ogg
2012-04-15 08:58:28 Verbose Configuration - OnQuestion_EventFile: C:\Program Files\VSO\Common\Sounds\OnQuestion_0409.ogg
2012-04-15 08:58:28 Verbose Configuration - OnProblem_EventFile: C:\Program Files\VSO\Common\Sounds\OnProblemDetected_0409.ogg
2012-04-15 08:58:28 Verbose Configuration - OnOperationComplete_EventFile: C:\Program Files\VSO\Common\Sounds\OnOperationComplete_0409.ogg
2012-04-15 08:58:28 Verbose Configuration - OnNewVersion_EventFile: C:\Program Files\VSO\Common\Sounds\OnNewVersion_0409.ogg
2012-04-15 08:58:28 Verbose Configuration - PlaySoundEvents: 0
2012-04-15 08:58:27 Info Supported instruction set: sse3
2012-04-15 08:58:27 Info Maximum number of threads detected: 2 - parallelize up to 2
2012-04-15 08:58:27 Info Tuning Performances for Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz with 2 core(s) CPU
2012-04-15 08:58:26 ---- ******************** Log session start 15-Apr 08:58:26.732 PID 5648********************
Thanks Doug
Does the player stop at the end of playback or does the time continue to increase?
Does it happen always or only with flv clips?
Best regards,
Felicià
Best regards,
Felicià
Felicia, rather than advancing to the next song, the time line continues to advance in silence at the end of a song.
I haven't tried it with media other than FLV files - I have been rendering files as FLV because of significant space savings over AVI (under 20MB vs over 700MB, where our projector resolution is only 640x480).
Thanks, Doug
Thanks, Doug
I have just purchased this program and it works very well. However I have a
question regarding the "playlist"
On a an older version I have the playlist come up at the beginning when
loaded and if I select the 1st show it will play the show to the end
and then go to the next show and so on consecutively, right to the very last
show. This is ideal for my grandchildren who can watch a few shows without
me being around.
On the new one when the first show is completed it goes back to the playlist
showing the start of each show on the disk and I have to click the show I
want to watch.
Is there a setting that allows me to do away with the new playlist and go
back to the old one which plays every thing it has on the DVD disk??
me being around.
want to watch.
First of all VMP is a absolutely free software, where did you buy it from?
Regarding your issue, from the proggrams menu select "Help/Report a bug". In the message window put "From Snowball to Felicià regarding playlist playback issue"
Best regards,
Felicià
Best regards,
Felicià
