evidently I changed a setting, but I can't figure out which one ...
I make a custom dvd, using a menu with six items ...
when I play the dvd, I select the title I want with the dvd remote, then it goes to a title menu and I have to hit 'play' a second time ...
what do I change to get it to go directly into the desired 'track' from the original boot menu ?
thanks much ...
double menus
Re: double menus
Two options;
- convert without title menu
- set your DVD player to play title instead of going to title menu
Re: double menus
thanks - will try it as soon as I can ...
Re: double menus
in the advanced settings under the tab "dvd video" you should also be able to check "skip root menu initially".
