[Bug] Episodic Blu-Rays
SeanC1966
Post by SeanC1966 »
I'm currently unable to rip all episodes from one Blu-Ray. I have to rip each one individually.
It creates files for all episodes. The first one is good @ 1.94GB the following episodes are all about 74MB and only appear to contain the soundtrack.
Using the settings MKV HD Ready 720P H264 CUDA, Custom size 10000MB. Forced subs only. Convert DTS to AC3. Don't generate chapters.
Here's the relevant section from the Log File which is also attached.
2012-07-13 10:34:53 Important ****************************************Conversion process : session end****************************************
2012-07-13 10:34:53 Info Conversion process completed successfully
2012-07-13 10:31:51 Info Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 224.000Kb/s]
2012-07-13 10:31:51 Info Converting track #1 : [VIDEO: h264_cuda - 1920x1080] to [VIDEO: H264_CUDA - 1280x720 - 5.806Mb/s]
2012-07-13 10:31:51 Info Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-07-13 10:31:51 Info Starting to encode Episode 5 (Default) output file with [MKV (Matroska) HD Ready (720p) H264 CUDA] profile
2012-07-13 10:28:54 Info Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 224.000Kb/s]
2012-07-13 10:28:54 Info Converting track #1 : [VIDEO: h264_cuda - 1920x1080] to [VIDEO: H264_CUDA - 1280x720 - 5.806Mb/s]
2012-07-13 10:28:54 Info Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-07-13 10:28:54 Info Starting to encode Episode 4 (Default) output file with [MKV (Matroska) HD Ready (720p) H264 CUDA] profile
2012-07-13 10:25:55 Info Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 224.000Kb/s]
2012-07-13 10:25:55 Info Converting track #1 : [VIDEO: h264_cuda - 1920x1080] to [VIDEO: H264_CUDA - 1280x720 - 5.806Mb/s]
2012-07-13 10:25:55 Info Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-07-13 10:25:55 Info Starting to encode Episode 3 (Default) output file with [MKV (Matroska) HD Ready (720p) H264 CUDA] profile
2012-07-13 10:22:56 Info Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 224.000Kb/s]
2012-07-13 10:22:56 Info Converting track #1 : [VIDEO: h264_cuda - 1920x1080] to [VIDEO: H264_CUDA - 1280x720 - 5.806Mb/s]
2012-07-13 10:22:56 Info Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-07-13 10:22:56 Info Starting to encode Episode 2 (Default) output file with [MKV (Matroska) HD Ready (720p) H264 CUDA] profile
2012-07-13 09:59:17 Info Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 224.000Kb/s]
2012-07-13 09:59:17 Info Converting track #1 : [VIDEO: h264_cuda - 1920x1080] to [VIDEO: H264_CUDA - 1280x720 - 5.806Mb/s]
2012-07-13 09:59:17 Info Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2012-07-13 09:59:17 Info Starting to encode Episode 1 (Default) output file with [MKV (Matroska) HD Ready (720p) H264 CUDA] profile
2012-07-13 09:59:17 Info 5 files to encode
2012-07-13 09:59:17 Info Output folder : E:\Downloads\Video
2012-07-13 09:59:17 Info Maximum target size : 9.77 Gb.
2012-07-13 09:59:17 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2012-07-13 09:59:17 Important ****************************************Conversion process : session start****************************************
2012-07-13 09:59:16 Info AV LOADER: File "index.bdmv" probed format is Any file in a Blu-Ray/AVCHD structure
2012-07-13 09:59:15 Info AV LOADER: File "index.bdmv" probed format is Any file in a Blu-Ray/AVCHD structure
2012-07-13 09:57:10 Info Video structure loaded successfully from:E:\Downloads\Video\Breaking.Bad.Season.4.Disc.1.mb2.BD25.DD51\BDMV\index.bdmv
2012-07-13 09:56:49 Info 9 Menu templates loaded.
2012-07-13 09:56:49 Info No disc in drive.
2012-07-13 09:56:48 Info Available Memory : 19134 Mb.
2012-07-13 09:56:48 Info Total Memory : 22252 Mb.
2012-07-13 09:56:48 Info Available extended Virtual Memory : 0 Mb.
2012-07-13 09:56:48 Info Available Virtual Memory : 1800 Mb.
2012-07-13 09:56:48 Info Total Virtual Memory : 2047 Mb.
2012-07-13 09:56:48 Info Memory Load : 25%
2012-07-13 09:56:48 Info Available Physical Memory : 8285 Mb.
2012-07-13 09:56:48 Info Total Physical Memory : 11127 Mb.
2012-07-13 09:56:48 Info System default language : English (United Kingdom)
2012-07-13 09:56:48 Info User default language : English (United Kingdom)
2012-07-13 09:56:48 Info Version : 1.4.0.8
2012-07-13 09:56:48 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2012-07-13 09:56:48 Info OS : Microsoft Windows 7 Home Premium (Build 7600)
2012-07-13 09:56:48 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-07-13 09:56:48 Info Drive has Serial ATA physical interface
2012-07-13 09:56:48 Info New Drive selected : 0:1:0 - hp DVD RW AD-7251H5 1H8D [D] (Ide)
2012-07-13 09:56:47 Info Using Advanced SPTI interface
2012-07-13 09:56:47 ---- ******************** Log session start 13-Jul 09:56:47.403 PID 4496********************
BR_and_DVD_Converters.log
(117.89 KiB) Downloaded 353 times
Re: [Bug] Episodic Blu-Rays
So in the output there is no video for all episodes except the 1st which is ok?
Can you try with beta version 2.0.0.11?
http://forums.vso-software.fr/blu-ray-c ... 15487.html
