I've downloaded loads of files now in format *.flv and selected no conversion. I've found playing the *.flv on Windows is OK, however playing them over SMB or UPNP (Twonky with conversion) on my WDTV the audio-video is not synced. Now I want to convert all the downloads, but how? I have ConvertXtoDVD, Blu-Ray Converter Ultimater & DVD Converter. The ideal solution would be a small tweak in VSO downloader to use local based files for conversion. Can this be built?
Request : Convert To Another Format
Re: Request : Convert To Another Format
We will release another application to do any format to any format video conversion. This will provide a solution for your situation.
The converter integrated in VSO Downloader will also change, but I am not sure it will solve your case. It will be changed so that even after a file has been downloaded, as long as it is listed in the VSO Downloader interface (and the original file is not deleted) the file can be converted.
