It has been around 3 months since we last had a new beta, is there a new beta coming soon?
Will HD audio support be coming? How about playing directly from a dvd disc? will bluray disc support be added too? I assume these betas will become paid versions if bluray disc playback is added?
New version coming?
Re: New version coming?
Thans for the interrest.
I hope a new version will be available before the end of next month.
As for the features you ask.
What type of HD audio are you trying to playback (DTS HD, AC-3 True HD, ...) ?
We already support dvd disc playback, just drag & drop the dvd from the explorer or click on the big play button on start up and select Open Blu-ray / DVD, then select the drive containig the DVD. The same goes for Blu-Ray. But for both you may need a decrypter such as AnyDVD if they are protected.
Best regards,
Felicià
Best regards,
Felicià
