can the MKV codec in bluray converter be used for
hdmaster
Post by hdmaster »
Is incredible but I'm converting my original blurays using AnyDVD and Bluray Converter Ultimate to MKV h264 in 720p HD and AAC3 audio. Results is amazing, with final file size of 1.2GB!!! I don't believe it, how an HD file of 2 hours can size less than 2 GB?
I converted with other bluray rip software and results are 5, 6 or even large files.
I'm wondering wich kind of encode is bluray conveter ultimate using? can I compress my already ripped blurays where size is 6GB using bluray converter?
Re: can the MKV codec in bluray converter be used for
When you watch the video are you satisfied with the quality?
Blu-ray converter supports Blu-ray folders and ISO files (with complete blu-ray structure), if your files are in a different format (like MKV, AVI) then Blu-Ray Converter will not support them.
Soon we will release a Video Converter where you can through anything at it and get any output.
