Detecting downloaded videos
Zero3K
Post by Zero3K »
Sometimes it'll try downloading videos/streams that have already been downloaded a while after they've been removed from the list of downloads or on the next run of it.
Benjamin
Re: Detecting downloaded videos
Post by Benjamin »
it makes sense, it will be updated in the next release (but you may also need to clean your cache)
Benjamin
Post by Benjamin »
this fix will create another problem so we cannot apply it: when the download is deleted as it is not in the list it will be re-detected if it is playing in the background
Zero3K
Post by Zero3K »
Let me clarify the issue for you. The previously downloaded streams/videos are being recorded when they're not even playing in the browser, etc.
