Mp4 Encoding Custom
Sat32
Mp4 Encoding Custom
Post by Sat32 »
I'm playing with new version of DVD Converter.
using a custom profile this is results I'm getting any Idea's on why??
[img]http://dl.dropbox.com/u/27773543/Untitled.jpg[/img]
LOG:
2012-09-08 11:47:46 ---- *** File encoded successfully: Episode 1.mp4 - ENTERPRISE_S2D4 - Episode 1 - Custom profiles ***
2012-09-08 11:38:03 Info Hardware decoding: MPEG-2 & MPEG-1 variable-length decoder using adapter #0 - NVIDIA GeForce GTX 560 Ti , vendor 0x10DE (NVIDIA), device 0x1200, revision 161, converting mpeg2video to yuv420p
2012-09-08 11:33:29 Info Hardware decoding: MPEG-2 & MPEG-1 variable-length decoder using adapter #0 - NVIDIA GeForce GTX 560 Ti , vendor 0x10DE (NVIDIA), device 0x1200, revision 161, converting mpeg2video to yuv420p
2012-09-08 11:33:29 ----
2012-09-08 11:33:29 Info scale#0(width=720, height=480, interpolation='gaussian', padding_method='automatic', crop_left=46, crop_top=0, crop_right=46, crop_bottom=0, pad_left=0, pad_top=34, pad_right=0, pad_bottom=34, pad_color=0)
2012-09-08 11:33:29 Info equalizer#0(contrast=1, brightness=0, saturation=1, gamma=1, gamma_weight=1, red_gamma=1, green_gamma=1, blue_gamma=1)
2012-09-08 11:33:29 Info rotate#0(rotation=ROTATE_NONE)
2012-09-08 11:33:29 Info deinterlace#0(mode=DEINTERLACE_FFMEG)
2012-09-08 11:33:29 Info ╔═> [audio #2 - aac audio, 48000Hz, 6 Ch., 240 Kbps [eng]]
2012-09-08 11:33:29 Info ╚══ [audio #2 - ac3 main audio, 48000 kHz, 6 Ch., 448 kbps [English]]
2012-09-08 11:33:29 Info ╔═> [video #1 - h264 video, 720x480, yuv420p, 3x2, 968 Kbps]
2012-09-08 11:33:29 Info ╚══ [video #1 - mpeg2video video, 720x480, YUV420P, 1.19]
2012-09-08 11:33:29 Info Limit video bitrate: 968Kb/s
2012-09-08 11:04:46 ---- *** File encoded successfully: Episode 1.mp4 - ENTERPRISE_S2D4 - Episode 1 - Custom profiles ***
2012-09-08 10:55:12 Info Hardware decoding: MPEG-2 & MPEG-1 variable-length decoder using adapter #0 - NVIDIA GeForce GTX 560 Ti , vendor 0x10DE (NVIDIA), device 0x1200, revision 161, converting mpeg2video to yuv420p
2012-09-08 10:50:47 Info Hardware decoding: MPEG-2 & MPEG-1 variable-length decoder using adapter #0 - NVIDIA GeForce GTX 560 Ti , vendor 0x10DE (NVIDIA), device 0x1200, revision 161, converting mpeg2video to yuv420p
2012-09-08 10:50:47 ----
2012-09-08 10:50:47 Info scale#0(width=720, height=480, interpolation='gaussian', padding_method='automatic', crop_left=46, crop_top=0, crop_right=46, crop_bottom=0, pad_left=0, pad_top=34, pad_right=0, pad_bottom=34, pad_color=0)
2012-09-08 10:50:47 Info equalizer#0(contrast=1, brightness=0, saturation=1, gamma=1, gamma_weight=1, red_gamma=1, green_gamma=1, blue_gamma=1)
2012-09-08 10:50:47 Info rotate#0(rotation=ROTATE_NONE)
2012-09-08 10:50:47 Info deinterlace#0(mode=DEINTERLACE_FFMEG)
2012-09-08 10:50:47 Info ╔═> [audio #2 - aac audio, 48000Hz, 6 Ch., 240 Kbps [eng]]
2012-09-08 10:50:47 Info ╚══ [audio #2 - ac3 main audio, 48000 kHz, 6 Ch., 448 kbps [English]]
2012-09-08 10:50:47 Info ╔═> [video #1 - h264 video, 720x480, yuv420p, 3x2, 968 Kbps]
2012-09-08 10:50:47 Info ╚══ [video #1 - mpeg2video video, 720x480, YUV420P, 1.19]
2012-09-08 10:50:47 Info Limit video bitrate: 968Kb/s
2012-09-08 10:43:49 ---- *** File encoded successfully: Episode 1.mkv - ENTERPRISE_S2D4 - Episode 1 - MKV (Matroska) ***
2012-09-08 10:24:50 ----
2012-09-08 10:24:50 Info scale#0(width=1280, height=720, interpolation='cubic', padding_method='automatic', crop_left=0, crop_top=0, crop_right=0, crop_bottom=0, pad_left=0, pad_top=0, pad_right=0, pad_bottom=0, pad_color=0)
2012-09-08 10:24:50 Info equalizer#0(contrast=1, brightness=0, saturation=1, gamma=1, gamma_weight=1, red_gamma=1, green_gamma=1, blue_gamma=1)
2012-09-08 10:24:50 Info rotate#0(rotation=ROTATE_NONE)
2012-09-08 10:24:50 Info deinterlace#0(mode=DEINTERLACE_FFMEG)
2012-09-08 10:24:50 Info ╔═> [audio #2 - aac audio, 48000Hz, 6 Ch., 224 Kbps [eng]]
2012-09-08 10:24:50 Info ╚══ [audio #2 - ac3 main audio, 48000 kHz, 6 Ch., 448 kbps [English]]
2012-09-08 10:24:50 Info ╔═> [video #1 - mpeg4 video, 1280x720, yuv420p, 16x9, 3858 Kbps]
2012-09-08 10:24:50 Info ╚══ [video #1 - mpeg2video video, 720x480, YUV420P, 1.19]
2012-09-08 10:24:49 Info Limit video bitrate: 3,858Kb/s
2012-09-08 10:24:49 ----
2012-09-08 10:12:07 ---- *** File encoded successfully: Episode 1.mp4 - ENTERPRISE_S2D4 - Episode 1 - Custom profiles ***
2012-09-08 10:00:48 ----
2012-09-08 10:00:48 Info scale#0(width=720, height=480, interpolation='cubic', padding_method='automatic', crop_left=0, crop_top=0, crop_right=0, crop_bottom=0, pad_left=0, pad_top=0, pad_right=0, pad_bottom=0, pad_color=0)
2012-09-08 10:00:48 Info equalizer#0(contrast=1, brightness=0, saturation=1, gamma=1, gamma_weight=1, red_gamma=1, green_gamma=1, blue_gamma=1)
2012-09-08 10:00:48 Info rotate#0(rotation=ROTATE_NONE)
2012-09-08 10:00:48 Info deinterlace#0(mode=DEINTERLACE_FFMEG)
2012-09-08 10:00:48 Info ╔═> [audio #2 - aac audio, 48000Hz, 6 Ch., 160 Kbps [eng]]
2012-09-08 10:00:48 Info ╚══ [audio #2 - ac3 main audio, 48000 kHz, 6 Ch., 448 kbps [English]]
2012-09-08 10:00:48 Info ╔═> [video #1 - h264 video, 720x480, yuv420p, 3x2, 1458 Kbps]
2012-09-08 10:00:48 Info ╚══ [video #1 - mpeg2video video, 720x480, YUV420P, 1.19]
2012-09-08 10:00:48 Info Limit video bitrate: 1,458Kb/s
2012-09-08 09:59:20 Info Video structure loaded successfully from:D:\Rips\ENTERPRISE_S2D4\VIDEO_TS\VIDEO_TS.IFO
2012-09-08 09:59:02 Info No disc in drive.
2012-09-08 09:59:01 Info 8 Menu templates loaded.
2012-09-08 09:59:01 Info Available Memory : 4647 Mb.
2012-09-08 09:59:01 Info Total Memory : 6124 Mb.
2012-09-08 09:59:01 Info Available extended Virtual Memory : 0 Mb.
2012-09-08 09:59:01 Info Available Virtual Memory : 1842 Mb.
2012-09-08 09:59:01 Info Total Virtual Memory : 2047 Mb.
2012-09-08 09:59:01 Info Memory Load : 45%
2012-09-08 09:59:01 Info Available Physical Memory : 1677 Mb.
2012-09-08 09:59:01 Info Total Physical Memory : 3063 Mb.
2012-09-08 09:59:01 Info System default language : English (United States)
2012-09-08 09:59:01 Info User default language : English (United States)
2012-09-08 09:59:01 Info Version : 2.1.1.4
2012-09-08 09:59:01 Info ExeName : C:\Program Files\vso\DVD Converter Ultimate\2\DVDConverterUltimate.exe
2012-09-08 09:59:01 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2012-09-08 09:59:01 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-09-08 09:59:01 Info Drive has Serial ATA physical interface
2012-09-08 09:59:01 Info New Drive selected : 0:0:0 - HL-DT-ST DVD-RAM GH22NS30 1.02 [E] (Ide)
2012-09-08 09:59:01 Info New Drive selected : 0:2:0 - HL-DT-ST BDDVDRW GGC-H20L 1.03 [F] (Ide)
2012-09-08 09:59:00 Info Using Advanced SPTI interface
2012-09-08 09:59:00 ---- ******************** Log session start 08-Sep 09:59:00.342 PID 4736********************
Sat32
Re: Mp4 Encoding Custom
Post by Sat32 »
oh and for the record mkv from the default presets work and the profile I was testing came from a encode done with handbrake that plays fine?
DVD Converter seemed to import the profile correctly just the output is messed up. My own Setting on a custom profile same messed up result.
Container = mp4
codex = x264
resolution = same as source
framerate = same as source
Sat32
Post by Sat32 »
After a little more testing doing short 1 minute encodes of bonus material. Changing settings check the results I figured out the problem, there is a flaw in the program.
640x480, mp4 or mkv, h264, 25fps = good results
640x480, mp4, h264, any framerate = good results
1280x720, mp4 or mkv, h264, 25fps = good results
720x480, mp4 or mkv, h264, 25fps = bad encode like the pic show
There is something wrong in the 720x480 resolution
Sat32
Post by Sat32 »
Hello VSO
Do you guys have anything to say?? is this just me can anyone else confirm.
Sat32
Post by Sat32 »
Hello hello
any body work here!!!
Anybody!! Hello
I'm doing tests to reproduce your problem and got same result with 720x480 mkv.
Hello Sat32... I'm here!
I will work on your problem today, a new beta with fix will be published too.
Can you say me if source DVD is interlaced?
It seems the problem appear when no resize is needed in conversion process?
Thank you!
Source 720x576 from CxD, so no interlace.
Conversion to 720x480 custom h264 mkv, 25fps and 23.97fps, green stripes on top of picture.
Conversion to 720x576 custom h264 mkv, 25fps, green stripes on top of picture.
Conversion to PAL DVD, no problems.
Conversion to 640x320 custom h264 mkv, 25fps, no problems.
Seems that it is as Sat32 found out, Custom Profile creation is making the problem with normal DVD resolutions.
Resizing height is not affecting, maybe resizing width might - but there is no option for other DVD resolutions in Custom.
Sat32
Post by Sat32 »
my source I was using was DVD NTSC 720 X 480 Progressive.
I don't think the issue is the "same as source" Setting it just happened to be 720 x 480 where the problem is.
I also tried turning off hardware acceleration thinking it might be a issue with nvidia's drivers.
Encodes with acceleration off failed totally within a few seconds.
I can't reproduce your problem here...
Tried 720x576 & 720x480 as output resolution and picture is OK!
I attached the custom profile I used for my tests, can you check if problem appear?
I worked around video processing in last beta version ( 2.1.1.8 ), maybe the problem was sorted out in this version:
http://oasis.vso-software.fr/Beta/Blura ... .1.1.8.exe
Thank you.
Test Sat32.rar
Test profile
(529 Bytes) Downloaded 528 times
Same problem with new version and your profile, green stripes across screen.
Sat32
Post by Sat32 »
mp4 encoding without hardware acceleration worked
Simultaneous gpu encoding through up an error "worked before"
Encoding 720 X 480 the hardware acceleration crashing program most of the time
when it did work was the same result as before black & white with green lines.
There a bigger flaw now Can't set the limit bit rate over 999 if you try to raise it past that with arrow
the program exits, if you try to type in a number higher than 999 it exits.
I will add processor optimization capabilities in next version log.
I think the problem can be in sse2 resizing optimizations, will try to disable sse4 here to see if I can reproduce.
Regards.
Works in my Virtual XP but not in my win7 system.
Something seems to be with CPU settings.
Sat32
Post by Sat32 »
if it matters system specs
asus p6t6 ws revolution
intel i920 @ stock speed
nvidia 560Ti x 2 (SLI)
Creative XiFI Platinum
Intel X25 SSD 160gb OS
WD 160gb x 3 (raid 0 array) work drive
LG DVD Burner
LG Bluray/HD-DVD Drive
Sat32
Post by Sat32 »
just did a quick test on VSO Blu-ray Converter Ultimate and it has the same issue with 720 x 480
Seems that the new versions weren't quite ready for prime time, Still Beta! releases
On a brighter note, The free handbrake converter still works great
and I figured how to do sub titles with it!
Did I mention handbrake is FREE and works better then the software I paid for.
Hello Sat32,
Your problem has been resolved in current beta version (2.1.1.11).
PS: thank you JJ for your great help...!
