Bitdefender told me how to make changes so that it worked properly with VSO Downloader - undertake handling, I tested it and it works.
Here are the steps - handling:
- Open Bitdefender and click the Firewall then click on Network Information
- In Network Activity, select Home / Office in Stealth Mode, select Off and select Yes in Generic
- Click on Close
- Still in the Firewall section, click on the (very) small sprocket.
- Check the Advanced tab of the firewall where the status of intrusion detection system is Off
- Also pass the switch Blog port scans to Off
- Then click on the Settings tab and check the paranoid mode is Off.
:D
Adjust Bitdefender 2013 for VSO Downloader - compatibility
Re: Adjust Bitdefender IS 2013 for VSO Downloader
Thank you very much for your useful post and the instructions!
Re: Adjust Bitdefender 2013 for VSO Downloader - compatibili
How do you adjust Bitdefender 2015 for VSO Downloader when it doesn't detect video?
Hi millvso!millvso wrote:How do you adjust Bitdefender 2015 for VSO Downloader when it doesn't detect video?
Try this:
In Bitdefender Internet Security 2015:
Go to Firewall settings --> Add Rule -->
Copy/paste this link:
c:\windows\system32\drivers\npf.sys
(select all kinds of network and then select allow)
and do the same to the following link:
c:\windows\system32\drivers\npfs.sys
Then Reboot your computer! (It's necessary for Bitdefender to "recognize" this 2 new exceptions!)
This 2 files from WinPcap (npf.sys, npfs.sys) are the one which are blocked by Bitdefender Firewall.
You just have to allow them to access to internet.
Worked perfectly for me!
Good Luck
