I just upgraded from Blu-Ray to DVD version 1.4.0.8 to Blu-Ray to DVD Ultimate version 2.1.1.14. To my surprise I found that any templates I created in version 1.4.0.8 will not work in version 2.1.1.14. Standard templates supplied with version 1.4.0.8 will not work in version 2.1.1.14 as well.
Is this a bug?
If not a bug, is there a simple way to translate templates in version 1.4.0.8 to 2.1.1.14?
Any help is appreciated.
Thanks in advance
Blu-Ray to DVD - Templates - 2.1.14 vs 1.4.0.8
Re: Blu-Ray to DVD - Templates - 2.1.14 vs 1.4.0.8
You have put them in the in the new v2 template folder?
can you post your template here please?
