PLEASE fix the few faults with 1.4.0.8
BenieUK
Post by BenieUK »
As a lifetime gold member i was wonder if you would be kind enough to fix the few little problems with version 1.4.0.8
I know all work has now gone into v2 but v1 is much much more stable and v1 GUI is a lot nicer / better also.. i will be sticking with v1 as it works much better, i hate the direction that v2 has gone.
v1 problems i would love to be fixed are as follows:
01. It cannot do the english forced subs out of Avatar .. they come out incorrect... v1 manages forced subs out of other blurays movies ok.
02. When you use the Audio setting to make the audio louder the result is loud crackling in the audio.
03. some profiles do not work, just error as soon as start.
If you could fix these and make a final of v1 i would be very happy.
Thank You.
Re: PLEASE fix the few faults with 1.4.0.8
Thanks for your post.
Are these problems in version 2? Another version of version 1 will not be made.
What is so bothersome for you with version 2's interface? Maybe understanding could help us make it better.
