Cannot Convert DVD
Cannot Convert DVD
For some reason I keep getting an error that says "Selected HD structure doesn't contain any valid video stream" whenever I try to convert a DVD. I have anydvd running and have no problems converting my DVD's it's just only happening when converting with DVD converter Ultimate 2.1.1.20. I have tried both of my optical drive without any success. The only way I am able to get it to work is to rip the DVD with AnyDVDHD and then load from folder and convert. Any help would be appreciated.
Re: Cannot Convert DVD
Yes. I am trying to make a backup file for my Rudolph the Red-Nosed Reindeer DVD so when my 4 year old niece and 2 year old nephew destroy it we wont have to buy a new one. That shouldn't be a problem though with the AnyDVD should it? I have made backups of a bunch of my other DVD's in the past with no problems. It has been a while since I did it though and now I can't get it to work with any of my DVDs. I have to rip all of them from the DVD with AnyDVD then load from folder to get it to convert.
Yes I'm here!
I think your problem will be fixed by installing last version:
http://www.vso-software.fr/products/dvd ... verter.php
Thank you!
Thank you!
THANK YOU THANK YOU THANK YOU!
It works perfectly now. What was wrong with 2.1.1.23 that was making it not work? I am assuming that this was not a problem specifically related to me but something to do with the program in general?
*Edit*
When did 2.1.1.25 get released? When I first had this problem I was on 2.1.1.20 I updated to 2.1.1.23 to try and fix it. Was 2.1.1.25 released in the last couple days?
*Edit*
2.1.1.25 version has been released yesterday (11-30-2012).
