When I download a stream of a model on http://www.ifriends.net, I get the following two errors even though it is able to download:
- Unable to check the connection: switching to live mode
- Unable to connect to stream
False errors are being logged
Re: False errors are being logged
that wants to mean that it is not yet supported
Huh? It doesn't need to switch to live mode in order to download that stream.
fyi, it needs to try to switch to this mode
You should try to figure out why it can't "check the connection" of iFriends.net, etc. streams.
Well? Will it be looked into or not?
