I like to make a feature request:
"Save to the same destination folder as source file" option as "output folder"
So what I mean is when I convert in batch from different source folders eg. D:\movies\The Hulk and from D:\movies\Dredd I want the converted file automatically saved to the source folder where the original is.
So the converted Hulk movie should be placed in the first folder and the Dredd movie should be placed in the second folder.
This would make my work much easier. The files always end up in the correct folder.
Thanks in advance.
Keep up the great!!!! work. I think your soft is solidly build and your responsetime on issues is great.
kind regards,
Coen
Feature request? output folder = source folder
Re: Feature request? output folder = source folder
This feature request has been entered here
http://bugs.vso-software.fr/view.php?id=6405
Thanks for your positive feedback
