V.135.461 VMP
david wong
V.135.461 VMP
Post by david wong »
It is a very nice designed player now.
The bug is VMP do not load SRT Chinese lang. subtitle, I have tried load to Potplayer have no problem loading and play well.
Re: V.135.461 VMP
Can you try with 1.3.6.464?
If it doesn't work can you post the subtitle files you are using?
http://forums.vso-software.fr/latest-vm ... 17317.html
