Error in activating USE Hardware Encoders Nvidia
avkmusic
Post by avkmusic »
My graphics card is NVIDIA
In all versions of the video tab menu setting options to enable USE Hardware Encoders Nvidia (CUDA) does not make any film I am faced with the error
** This is an error **
((( an error occured while converting )))
Please fix this problem
Thanks for your efforts
Re: Error in activating USE Hardware Encoders Nvidia
Hello avkmusic,
What is the reference of your graphic card?
Can you post your log file please?
avkmusic
Post by avkmusic »
Appreciate
My Graphic Card = Nvidia Geforce 9500 1Gb
logfile=
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\5\log\VideoConverter_mainlog_.20130705.122837.441.log'
:library=false
:app_name=VideoConverter.exe
:app_version=1.0.0.21
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
12:28:37.439 ------------ ***************VideoConverter.exe:4504 Log session stop after 1 minute(s) 4 second(s) 693 millisecond(s)****************
12:28:29.262 Info An error occured while converting
12:28:29.187 Error Error while initializing file: Prkr-2013-720p_IMDB-DLCom.mkv - Custom profiles My MKV
12:28:28.692 ------------ ??> [audio #2 - aac audio, 48000Hz, 2 Ch., 192 Kbps [en]]
??? [audio #2 - aac main audio, 48000 kHz, 2 Ch. [English]]
??> [video #1 - h264_cuda video, 720x480, , 3x2, 23.98Fps, 377 Kbps [un]]
??? [video #1 - h264 video, 1280x536, 23.98Fps, YUV420P, 1.00 [Unspecified]]
************* -> Prkr-2013-720p_IMDB-DLCom.mkv - My MKV *************
12:28:28.442 Group ******************** Prkr-2013-720p_IMDB-DL.Com.mkv -> Prkr-2013-720p_IMDB-DLCom.mkv ********************|GK_TITLESET|
12:28:28.436 Group File encoding session started at 12:28:28 عصر: 1 sequence(s) to encode|GK_CONVERT_SESSION|
12:27:25.652 Info Total Physical Memory : 3325 Mb.
Available Physical Memory : 1616 Mb.
Memory Load : 51%
Available Virtual Memory : 1877 Mb.
Total Memory : 7411 Mb.
Available Memory : 3495 Mb.
12:27:25.651 Info Processor Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz with 2 core(s) CPU
Pipeline(s): 2 - parallelize up to 2
Supported instruction set: MMX,sse,sse2,sse3,ssse3 (slow),sse41
12:27:25.628 Info OS : Windows 7 (32 bits), Build 7601, service pack 1.0
file name : C:\Program Files\VSO\VSO Video Converter\1\VideoConverter.exe
file version : 1.0.0.21
12:27:25.625 ------------ **************************VideoConverter.exe:4504 Log session start 2013-07-05 at 12:27:24.568**************************
Hello avkmusic,
Please can you try to install last official Nvidia graphic card driver (not the beta version)?
http://www.nvidia.com/content/DriverDow ... pe=GeForce
I tried to reproduce here with same graphic card, no problem...
Thank you.
avkmusic
Post by avkmusic »
I had already installed the latest graphics driver version.
I installed the 1.0.0.22 version of software that will fix the problem.
The high conversion rate but lower quality version of the video mode is checked.
In previous versions of the H264 codec conversion speed and high quality, but low in the low quality version 1.0.0.22.
Also, the sound quality is not higher than 96kb
Thanks for the great work you and your colleagues.
Brainiarc7
Post by Brainiarc7 »
avkmusic wrote:Appreciate
logfile=
:library=false
:most_recent=first
:status=stopped
:group_indent=4
Memory Load : 51%
Your GPU does not support Nvidia NVENC's technology.
NVENC is only supported on Kepler (GTX 700-series) and Maxwell (GTX 800M/900 series ) GPUs.
Hardware upgrade required prior to activating and using the technology.
