can't figure out the settings for my dv player
krysavy
Post by krysavy »
Hi!
Hoping someone will take pity and lend me a clue, or at least tell me if what I want to do is possible. I do have gold membership, so I could use other vso products if one of those is better... thanks in advance. :)
I have an ivew-103dv dvd/media player that will play some avi files from a usb drive but it fails to recognize most of my existing avi files and all of my conversions. mainly I just want to be able to convert video files as needed so that I can play them in this thing from a jump drive, but trial and error isn't getting me anywhere. I think I have tried all the avi combinations in this program and dvd converter as well, without success, so maybe the codec I need isn't even supported. ?
Its Specs say:
Playable Video Codecs: MPEG1, MPEG2, MPEG4 (DivX) with QPEL, GMC (1 warp point), b-frames with packed bitstream
Playable Audio Types: MP3 2.0 (CBR, VBR, SBR), WMA9 2.0 (CBR, VBR)
Playable Video Containers: AVI, DivX
any advice?
Re: can't figure out the settings for my dv player
Begin by downloading Mediainfo (http://mediaarea.net/en/MediaInfo/Download) and check the properties of the file that plays well on your device. Try to use the same settings in the converter.
You can also copy the properties of the file that plays well from Mediainfo and paste them in your post. I'm sure that one of the VSO team will be able to advice you.
krysavy
Post by krysavy »
Thanks Coral, I had made it that far on my own already, actually, but still can't seem to reproduce the output.
Here is the info on a file that plays okay:
[quote]Format : AVI
Format/Info : Audio Video Interleave
File size : 1.79 GiB
Duration : 2h 10mn
Overall bit rate : 1 970 Kbps
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1853/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : Yes
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 10mn
Bit rate : 1 702 Kbps
Width : 720 pixels
Height : 288 pixels
Display aspect ratio : 2.500
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.274
Stream size : 1.55 GiB (86%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 2h 10mn
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : 14ms
Stream size : 238 MiB (13%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
[/quote]
Here is the info from another file with different encoding that also plays fine.
[quote]Format : AVI
File size : 549 MiB
Duration : 1h 18mn
Overall bit rate : 973 Kbps
Writing application : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
Writing library : VirtualDub build 32618/release
Video
Format settings, QPel : No
Codec ID : XVID
Duration : 1h 18mn
Bit rate : 779 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.144
Stream size : 440 MiB (80%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 18mn
Bit rate mode : Variable
Bit rate : 180 Kbps
Nominal bit rate : 192 Kbps
Stream size : 102 MiB (19%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 102 ms
Writing library : LAME3.97
Encoding settings : -m j -V 4 -q 2 -lowpass 18.6 --abr 192
[/quote]
As I said, I tried every avi output including the muxing, also a couple custom configurations, without success, making me wonder if it is even possible to reproduce the output format with this software...
Coral wrote:Begin by downloading Mediainfo (http://mediaarea.net/en/MediaInfo/Download) and check the properties of the file that plays well on your device. Try to use the same settings in the converter.
WOW this is a great application for providing info on a source file, when having issues with a specific file.
I'm sure all the info is valuable to VSO Tech Support, thank you !
I installed it to look at a few files, most of the info is all chinese to me but as I said probably real useful to others :)
Hello krysavy,
Have you compared file properties from files with the same extention ?
For example, an avi file which plays fine against an avi file that will not play.
krysavy
Post by krysavy »
Yeah, I only ask for help as a last resort. I tried all that before posting here,
I really need VSO to let me know if any of their stock or custom configurations are capable of outputting to match the specs. At this point, I kind of guess the answer will be No and I will have to give up on the idea of sending this off to my Dad full of files and just use it for DVDs. I can ;ive with that, but if there is a setting that will work, or if they are working on one, it would be nice to know.
THanks again,
Hello krysavy,
Please can you try the custom profile I made (in attachment).
PS: have you tried to create a custom profile by using the "Get profile from sample file..." function in custom profile editor? Can you try with Generic Video/Mpeg2-PS format?
Thanks you!
krysavy.rar
(494 Bytes) Downloaded 484 times
krysavy
Post by krysavy »
Thanks!! When I found the create custom profile from sample file function, I thought it would solve my problem, but it didn't work for me either.
I downloaded the rar, extracted to an xml file, then moved it into the custom profile folder of the program. I assume that will allow me to select the profile.
Right now I am trying a conversion from MPEG-2 PS NTSC16-9, since I think I tried that the other day, but can't be 100% sure as it has been a few days now and I did get tired of trying things and eventually give up...
Next I will try the custom profile you created, and if that doesn't work, I will try the 'create profile from sample file' again, then compare the output and report back.
Thanks for your help.
krysavy
Post by krysavy »
I am not as smart as I thought .... like most who post here probably, lol!
Moving the xml file as described doesn't make it show in the list of formats, please tell me, how do I use it?
Uncompress the attached file in "C:\ProgramData\VSO\VSO Video Converter\1\custom_profiles" then restart the program...
krysavy
Post by krysavy »
Odd, since that is what I did (guess I am not *totally* stupid after all lol), but the custom profile isn't showing up there even repeating the process or after a pc reboot. Lucky for me, it doesn't matter, since your first suggestion was the winner. :-)
I had gotten hung up on trying the avi format, since all user reviews of the dv player that I found mentioned only "some avi files" working, and none of the mpg files that I tested at first played at all... nevertheless, the generic mpeg-2 ps format does play for me in the device! Yahoo! Thanks for helping me figure this out. VSO rocks, and I have never once regretted buying my gold membership.
