Still Problem With Profiles
I am still having problems when trying to save a profile. The following are my settings and message after clicking OK:
Re: Still Problem With Profiles
Can you try by removing the ":" character in profile name?
cedric wrote:Can you try by removing the ":" character in profile name?
Yes, it is the colon (:) which is causing the error. I have used it in previous versions and had no problems as far as I can remember.
I am finding it impossible to save an NTSC profile. It is changeing to PAL with a wrong resolution.
profile name.jpg (14.35 KiB) Viewed 3887 times
