Couple of questions for new user
TheTinker
Post by TheTinker »
Just bought the key to Blueray to DVD program. Noticed on the trial version it had no "two pass encoding" selection on it, but guessed it was not on the trial version. <wrong> Not on the licensed version either. Is it no longer an option? Re: Advanced settings>General settings>Two passes encoding.
And, a second question to shorten the learning curve: Is it possible to save a Blu-ray to DVD directly to an .iso file on HDD? :?
TheTinker
Re: Couple of questions for new user
Post by TheTinker »
Clone DVD will convert video DVD file to .iso, but hoping there was a 1-step available in the program... Guess not :|
There is no real need to create ISO.
All you need is folder containing VIDEO_TS and AUDIO_TS folders.
That is exactly what is inside DVD or ISO.
TheTinker
Post by TheTinker »
JJ wrote:There is no real need to create ISO.
An .iso is a more compact (single) file as on a long hdd list; I prefer that to the long list of folders... just my preference. :|
TheTinker
Re: No Questions from EX-User
Post by TheTinker »
I found this program to be more trouble than it is worth. Rather just buy a couple large HDD's and keep Blu-ray format :roll:
iso output has been added in latest beta version available in forum (1st thread)
