Video Converter 1.1.0.1
I convert .mkv 1080px files to standard Xvid TV size 720px but choosing custom resolution does nothing - it still reconverts to original size. On the other hand, choosing presets works fine e.g. choosing 720x480 etc.
Can you fix it?
Thank you!
Custom Resolution Does Not Work
Re: Custom Resolution Does Not Work
The latest version up to this date is 1.1.0.3. Have you checked this version ?
As far as I can see the latest version is Video converter - 1.1.0.1 (Released 2013-08-30). Where do you get Video converter - 1.1.0.3, it is not posted on the website?
Hello monet60707
1.1.0.3 is the last beta version. You can find the last published beta versions on the first post of Video Converter forum:
http://forums.vso-software.fr/new-vso-v ... 17272.html
Video converter - 1.1.0.3 (Released 2013-09-04) [ View Issues ]
- 0006957: [Bug] Tree items not displayed correctly after a conversion process (cedric) - resolved.
- 0006956: [Bug] Bad aspect ratio (4/3) when using DVD Video NTSC 16/9 profile (cedric) - resolved.
[2 issues]
[2 issues]
