Converting .mov to .mp4, no sound.
I tried converting a few .mov vids I had taken with my camera to .mp4. It converted the video but there is no audio. i screwed up cause I deleted the .mov's before I actually checked the mp4s. I lost 4 vids (that now have no sound) this way. Now I can't be so quick to trust this program is working properly. I guess the saying, "trust but verify" holds true here. My mistake
Re: Converting .mov to .mp4, no sound.
Of course you should always verify results before deleting source.
Still I wonder about your problem, logs might reveal something.
Actually the only one of the MP4 options that didn't have sound (from converting a mov) was MP4-Mpeg4. Using either of the other 2 MP4 options had sound.
Also I got my sounds back on those other ones. I just converted them again to avi and got the sound back. So at least I didn't lose anything. Appears those files didn't like the MP4-Mpeg4 conversion option.
Hello Mike89,
If the audio tracks are back after converting to AVI, I think your problem can be the video player you use to check your converted files.
What player do you use? Is it able to play AAC audio format?
The stock Windows Media Player
