My problems occured several times.
1 problem : First I create a user Profile. Give it a name, select options i like. for example create m2ts for bluray. codec h264 , resolution and framerate :same as source ,16/9, maximum bitrate 2500, audio ac3 5.1 96kb/s 48k and subtitles : merged in video. after starting the conversion I get an error. if subtitles : dvd-subtitles. it works sometimes.
Now when I want to edit my profile : i got the message : ' "" is not an integer value ' This happens only in the beta version in the stable version I can edit my profile.
2 Problem : when Finetuning Subtitles settings after a few times suddenly the font name is gone and I cant select a Font. I then have to restart the program. this happens in the stable and beta versions.
I would like to convert my series and burne the subtitles in the video if possible , or save the subtitle as a sony DVD Architekt pro 6.0 formated sub.
Hope you can fix it.
greetings, Harald
Problem when fine tuneing for subtitles.
