Hello
when I convert DVD to MKV or any other format, I leave it as 4:3 (fullscreen) when it should be 16:9 (widescreen) video ...
as set up for me to leave it in 16:9 format in the custom profile?????
See this picture [url]http://forums.vso-software.fr/download/ ... aspect.jpg[/url]
thanks ....
In my profile
My profile just like so in the archive xml ...
<?xml version="1.0" encoding="Windows-1252" standalone="no"?>
<Configuration>
<VSO_custom_profile>
<Description/>
<DefaultFileExtension>mkv</DefaultFileExtension>
<FileFormat>mkv</FileFormat>
<ContextName>Rosswell MKV</ContextName>
<VideoProfile>
<Item0>flags=+global_header</Item0>
<Item1>codec=h264</Item1>
<Item2>preset=medium</Item2>
<Item3>h264_profile=high</Item3>
<Item4>h264_level=4</Item4>
<Item5>width=720</Item5>
<Item6>height=480</Item6>
<Item7>aspect=1</Item7>
<Item8>time_base=1001/30000</Item8>
<Item9>max_b=1500000</Item9>
<Count>10</Count>
</VideoProfile>
<AudioProfile>
<Item1>codec=raw</Item1>
<Count>2</Count>
</AudioProfile>
<SubtitleProfile>
<Item1>codec=dvd_subtitle</Item1>
<Count>2</Count>
</SubtitleProfile>
<ImageIndex>16</ImageIndex>
<TemplateName>Custom profiles</TemplateName>
<editor_link>FALSE</editor_link>
</VSO_custom_profile>
</Configuration>
DvD converter Ultime 3...aspect ratio????
Re: DvD converter Ultime 3...aspect ratio????
This has been solved in the version published yesterday
http://www.vso-software.fr/products/dvd ... verter.php
