Before I buy this software can someone give me an average file size of a converted Blu-Ray to mp4? I am looking to get a 2gb or under filesize and have not found any programs to get down to that size. I always get 5+ gb which is too big for my needs.
bman1096 :D
Average file size
Re: Average file size
End size is result from input file and output resolution.
Getting under 2Gb from BR original is possible, but then you need to reduce resolution dramatically. You simply can not have HD resolution and under 2Gb filesize, even DVD resolution is usually too much for that size.
However, if you are happy with lower resolutions, sure you can do it. 320*256 sized output should give nicely under 2Gb result.
Other option is to use 10bit encoding, but that is still very rare and can not be played on most hardware. (and it is not available output option on this software)
