i´ve upgrade to the new Version of Blu-Ray Coverter Ultimate 3 and i missed the Quality Advisior on the UI.
Is there somewhere in the settings an entry to enable?
Thanks vor Help
Greetings Teralin
Quality Advisior in new Blu-Ray Converter?
Re: Quality Advisior in new Blu-Ray Converter?
If you go into the editing window select a video stream and then you can find it in one of the tabs related to the editing of that stream.
Ahhh Thanks,
i see it now thats great thanks for the fast Help
Greetings Teralin
Greetings Teralin
