Conversion Speed
new915
Conversion Speed
Post by new915 »
Hi All,
Wondering if you all could help me to check if this desktop would speed up my conversion speed.....I am currently using a sony laptop that takes 12 hr plus to do conversion.....
Will this work
Genuine Windows 8
CPU Intel® Core™ i7-4770
Chipset Intel® H87
Graphic Nvidia GTX760 192bit 3GB DDR5
Memory 32GB at 1600MHz 4 x DIMM
Storage 1TB SATA hard drive (7200rpmRPM)
Optical Drive BD Combo Drive
Wireless Data Network 802.11AC + BT 4.0
LAN 10/100/1000Mbps
Or does someone want to build me a good one for burning and converting
Re: Conversion Speed
new915 wrote:Hi All,
Are you joking or bragging?
That system you listed will convert in minutes instead of hours, quite a beast!
new915
Post by new915 »
Ill be bragging once I get it......wasn't sure if its what I needed to speed up my conversions,
