Latest beta version 3.1.0.30
Latest beta version 3.1.0.30:
see http://forums.vso-software.fr/latest-be ... 17959.html
Latest official (stable) version is 3.0.0.20:
- Blu-ray Converter
- DVD Converter
Blu-ray & DVD Converters - 3.1.0.30
- 0007544: [Bug] cant remux to mkv (cedric) - resolved.
- 0007543: [Bug] cant load dvd in dvd converter (cedric) - resolved.
Blu-ray & DVD Converters - 3.1.0.29
- 0007530: [Bug] missing system info in log file (cedric) - resolved.
- 0007381: [Bug] Remaining time behind pass 2/2 is incorrect. (cedric) - resolved.
- 0007443: [Information] missing word 'structure' for new profiles? (cedric) - resolved.
- 0007486: [Feature Request] compile with updated EULA from SVN (cedric) - resolved.
- 0007520: [Bug] cannot open edit window (cedric) - resolved.
Blu-ray & DVD Converters - 3.1.0.28
- 0007513: [Bug] Getting "Failed to set data for NetUpdate_LastCheck" error after installing (cedric) - resolved.
- 0007512: [Suggestion] Give better visibility to main tree (show more difference between selected/unselected items) (cedric) - resolved.
- 0007511: [Feature Request] Add different "burn to disk" options for single file, DVD and Blu-ray outputs (cedric) - resolved.
- 0007510: [Feature Request] Add a search module in settings window to find a specific setting quickly (cedric) - resolved.
- 0007509: [Suggestion] right click on titleset and have no options (cedric) - resolved.
- 0007508: [Bug] conversion failed 2 pass - log info: requested bitrate is too low (cedric) - resolved.
- 0007507: [Information] conversion advisor estimated size is a bit off (cedric) - resolved.
Blu-ray & DVD Converters - 3.1.0.27
- 0007451: [Bug] cant burn blu-ray stucture from already converted file (cedric) - resolved.
- 0007433: [Crash] Get access violation when trying to remove a track in Video editor (cedric) - resolved.
- 0007432: [Bug] Clicking on setting menu items (main window) always open language tab (cedric) - resolved.
Blu-ray & DVD Converters - 3.1.0.26
- 0007383: [Bug] av when trying to convert (cedric) - resolved.
- 0007093: [Bug] invalid input error when modifying cut (cedric) - resolved.
- 0007414: [Bug] av can't convert not matter what profile (cedric) - resolved.
Blu-ray & DVD Converters - 3.1.0.25
- 0007377: [Bug] estimated converted size is much different than final result (cedric) - resolved.
- 0007360: [Bug] last position on window no remembered (cedric) - resolved.
- 0007366: [Bug] Can't convert using Mpeg-2 PS/TS output format (cedric) - resolved.
- 0007364: [Suggestion] Show burn process progression in Windows 7/8 task bar (cedric) - resolved.
Blu-ray & DVD Converters - 3.1.0.24
- 0007358: [Feature Request] Implement "Best video quality settings" option (cedric) - resolved.
- 0007354: [Suggestion] Store generated ISO file to output folder ROOT (cedric) - resolved.
Blu-ray & DVD Converters - 3.0.0.23
- 0007352: [Bug] If drive has 0 bytes left, conversion keeps on going to the end (No warnings) and ends with an error. (cedric) - resolved.
- 0007350: [Bug] Can't load a Blu-ray/AVCHD structure backup (cedric) - resolved.
- 0007336: [Feature Request] do not remove commas in file name (cedric) - resolved.
- 0007348: [Feature Request] Add an option to set output target size for single files (mkv, avi, mp4, webm...) too (cedric) - resolved.
Blu-ray & DVD Converters - 3.0.0.22
- 0007323: [Feature Request] The main quality advisor is finally back... (usefull for HD structure output) (cedric) - resolved.
- 0007319: [Bug] drop down "burn settings" links to chapters (cedric) - resolved.
- 0007318: [Bug] preview window odd behavior (cedric) - resolved.
- 0007317: [Bug] style and name missing from burning window (cedric) - resolved.
- 0007304: [Information] cannot minimize burn window (cedric) - resolved.
- 0007316: [Bug] no link to hd structure in settings drop down list (cedric) - resolved.
Blu-ray & DVD Converters - 3.0.0.21
- 0007287: [Feature Request] a way to limit BR creation to 25 or 50 gb (cedric) - resolved.
- 0007302: [Bug] double pass encoding doesn't works in some cases (cedric) - resolved.
- 0007293: [Bug] aspect ratio problem (cedric) - resolved.
- 0007301: [Feature Request] Display estimated output file size in tree (cedric) - resolved.
- 0007300: [Information] no save or cancel in subtitle style settings window (cedric) - resolved.
- 0007280: [Bug] color of subtitles not respected converting to Blu-ray (felicia) - resolved.
- 0007277: [Feature Request] correct wording "action after conversion" (cedric) - resolved.
krypdo
Re: Latest beta versions 3.0.0.22
Post by krypdo »
Stuck at "loading all the video parts, please wait...". using ripped blueray iso.
krypdo
Post by krypdo »
Is there a beta 3.0.0.21? My problem (aspect ratio) was supposedly solve in that version?
any higher version still should have the problem fixed (like 3.0.0.22)
krypdo
Post by krypdo »
I mean I'm having this problem "Stuck at "loading all the video parts, please wait...". using ripped blueray iso." with 3.0.0.22. I can't even start a conversion to see if my aspect ratio problem was fixed. :(
Goetschi
Post by Goetschi »
It isn't possible to choose bitrates over 128 Kbit/s, even not at own created custom profiles.
I use MKV H.264 - AC3/ 6 channels (5.1)/ max. bitrate 128 Kbit/s choose able.
5.1 standard allows max 640kbit/s for total. If you have 5 channels with 128k - that uses it all.
Re: Latest beta versions 3.0.0.23
The audio bitrate setting is a "bitrate by channel" value, not an average bitrate value...
That mean if you select 128Kbit/s, you will get a 768Kbit/s average bitrate on a 5.1 output profile.
There might come problems with some players if 5.1 has total over 640kbit/s as standard defines it to be maximum, and even less on DVD (348/448).
Usually with computers there is no problem playing out-of-specs but DVD/BR hardware might be limited.
http://www.dolby.com/us/en/consumer/tec ... gital.html
Goetschi
Re: Latest beta version 3.1.0.25
Post by Goetschi »
In version 3.1.0.20 "merged in Video" subtitles don't work by Output Format "mkv".
So I tried the beta version 3.1.0.25, but there always comes the fault message "Access violation at address 00D1A0DE in module 'BlurayConverterUlitmate.exe'. Read of adress 00000014.".
Thank you Goetschi for your feedback,
I will try to reproduce/fix this problem soon...
ArmadilloMan
Post by ArmadilloMan »
I just wanted to add that in 3.1.0.25 I am also getting the error "Access violation at address 00D1A0DE in module 'BlurayConverterUlitmate.exe'. Read of adress 00000014." This happens in both BluRayConverter and DVDConverter, using built in and custom profiles whenever I click start to try to convert a movie. Let me know if you need any additional information to help diagnose this issue.
@ArmadilloMan
@Goetschi
can you post your log files please or at least give more info about the settings in your custom profiles. Also please tell us what type of source files you are using.
So far I cannot reproduce.
elvaron
Post by elvaron »
The same problem: "Access violation at address 00D1A0DE in module 'BlurayConverterUltimate.exe'. Read of address 00000014". Just after I click Start. Unfortunately logs shows nothing :-(
Windows 8.1 and latest beta of Blu-ray Converter, built-in output format MKV H264.
Blu-ray Converter Ultimate 3_mainlog_.20131218.184908.987.log
(1.88 KiB) Downloaded 782 times
Blu-ray Converter Ultimate 3_crashlog_.20131218.184552.910.log
(2.33 KiB) Downloaded 774 times
Robert
ArmadilloMan
Claire wrote:@ArmadilloMan
@Goetschi
I'm actually not sure where the logs are stored, I've looked in the program folder, AppData folder, and the Windows event viewer and haven't seen logs anywhere. Regardless, here is some additional information:
- I have uninstalled BluRay/DVD Converter Ultimate, deleted all remaining files, and removed all remaining entries in the registry. After reinstalling, the problem persists with all default profiles (including the remux only profile)
-The problem persists whether or not two-pass encoding and "Use best video quality settings" are checked
-The problem persists whether hardware encoding/decoding is enabled
-The problem persists regardless of quality factor (size or slider)
-The problem persists whether or not the program is run with administrative rights
-The problem occurs whether loading from .iso, a folder, or from either of my disc drives (one connected via SATA2 and one USB)
- I can play the entire DVD or blu-ray from within DVD and Blu Ray Converter ultimate video editor
- The problem persists no matter which audio tracks are selected (even if no audio or subtitle tracks are checked)
- The problem persists with antivirus disabled
System Information:
Windows 7 x64 SP1 (with latest updates)
i7-2600k CPU @ 3.7GHz
16GB DDR3 RAM @ 2133Mhz
Gigabyte Geforce GTX 670 3GB DDR5 (Driver version 331.65)
Wow, so nothing converts at all it seems. You provided very detailed info - thank you.
In the software got to Help/Tools and from there select to show the log, at the bottom of this new window you will see a button "open log folder".
I am pretty sure I reproduced the problem and reported it here
http://bugs.vso-software.fr/view.php?id=7414
ArmadilloMan
Re: Latest beta version 3.1.0.26
New version works really well and I like the new settings interface! Thanks for all your hard work!
Goetschi
Post by Goetschi »
New version works well and I like the new settings Interface too! You've made a good job! :wink:
But I still have the problem, that the subtitle not shown in the converted mkv-film, when I choose "merged in video"! :(
Hello Goetschi,
It seems you created a custom profile with "Merged in video" setting as subtitle codec?
But what do you selected for Video codec? Do you selected remux?
I need to disable "Merged in video" option for subtitles if video codec is set to remux (because merged subtitles option can't be used if video is not decoded/reencoded)
