Create a DVD using the "Default, Simple Menu" on both Video Converter 1.1.0.20 and ConvertXtoDVD 5. Select "Skip root menu initially" option on both programs.
- On CXD5, the root menu is skipped correctly.
- On VC1 the option is always ignored. The root menu always appears.
The templates on both programs are identical.
Try also with the free Xmas template at http://forums.vso-software.fr/new-extra ... 17685.html, same problem.
Please fix asap, thanks!
Video Converter ignores "Skip root menu initially" option
Re: Video Converter ignores "Skip root menu initially" optio
Thank you sheepie for your feedback, problem reproduced then fixed.
You just need to wait for the next release...
