beta version 1.1.0.30
beta version 1.1.0.30:
- link removed-
Latest official (stable) version is 1.1.0.29:
http://www.vso-software.fr/download_pro ... oconverter
Video converter - 1.1.0.30
- 0007556: [Feature Request] load program faster (cedric) - resolved.
- 0007517: [Information] right click on top notch 'rename' greyed out (cedric) - resolved.
- 0007518: [Feature Request] in settting search, enter should skip to next section where items is found (cedric) - resolved.
- 0007519: [Bug] link conversion advisor links (size + quality) to correct setting (cedric) - resolved.
- 0007542: [Bug] wording (cedric) - resolved.
- 0007548: [Feature Request] rename default exe compiled file nanme (cedric) - resolved.
- 0007545: [Information] different browser windows (cedric) - closed.
Video converter - 1.1.0.29
- 0007469: [Information] harmonize top menu buttons (cedric) - resolved.
- 0007516: [Information] add "2 pass" to hint in settings (cedric) - resolved.
- 0007527: [Bug] Getting "AV LOADER: ... can't be opened in protocol hd" error (cedric) - resolved.
- 0007532: [Bug] Subtitle settings (color, size...) changed in video editor not taken in account (cedric) - resolved.
- 0007522: [Bug] subtitles not same size on preview and conversion (cedric) - resolved.
Video converter - 1.1.0.28
- 0007470: [Information] conversion advisor estimated size is a bit off (cedric) - resolved.
- 0007394: [Bug] conversion failed 2 pass - log info: requested bitrate is too low (cedric) - resolved.
- 0007148: [Information] right click on titleset and have no options (cedric) - resolved.
- 0007506: [Feature Request] Add a search module in settings window to find a specific setting quickly (cedric) - resolved.
- 0007498: [Feature Request] do not limit burning .... (cedric) - resolved.
- 0007499: [Feature Request] Add different "burn to disk" options for single file, DVD and Blu-ray outputs (cedric) - resolved.
- 0007500: [Suggestion] Give better visibility to main tree (show more difference between selected/unselected items) (cedric) - resolved.
- 0007489: [Bug] Getting "Failed to set data for NetUpdate_LastCheck" error after installing (cedric) - resolved.
Video converter - 1.1.0.27
- 0007453: [Bug] only ejects when you press ok on dialogue after successful burn (cedric) - resolved.
- 0007389: [Bug] both audio streams become deactivated during editing (cedric) - resolved.
- 0007392: [Feature Request] once editor window opened and resized it will always open in upper right hand side of screen (cedric) - resolved.
- 0007431: [Bug] Clicking on setting menu items (main window) always open language tab (cedric) - resolved.
- 0007430: [Crash] Get access violation when trying to remove a track in Video editor (cedric) - resolved.
- link removed-
Re: Latest beta version 1.1.0.24
This latest version 1.1.0.24, is causing an error when converting. If I choose to delete the partialy conveted file all the folder contents will be deleted. So if I save on the desktop anyting on the desktop will also be deleted.
No problem with version 1.1.0.23.
Hello Coral,
Please give me more details about your conversion problem (log file)
Sory. I should have posted the log.
Here they are:
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Here they are:
- Logs.rar
- (2.31 KiB) Downloaded 516 times
Thank you Coral for the log files, problem fixed for the next version...
OK Cedric. Thanks.
Re: Latest beta version 1.1.0.25
This version is now working fine.
Would it be possible to include 50 fps ? Also, I would like to join movie files (mts) without re-encodeing (lossless)
Hello Coral,
Sorry, but I will not include 50 Fps (interlaced) frame rate choice because we produce progressive videos only.
"I would like to join movie files (mts) without re-encodeing (lossless)"
If I understand, you want the ability to select "remux video" and "remux audio" when selecting mts container in video profile editor?
If yes, I will need to add some additional checks in case of input file use a codec not supported by mts container (like VP8, Xvid...)
Hello Cedric,
Thanks for your reply.
I have MTS movie clips taken with my Canon Legria HF R406. It would be nice if I can join them using the converter. This would save me using another application. At the moment I am using Aunsoft Final Mate to do the job. This joins the clips into one MTS movie without re-encodeing, thus leaving the same movie properties and doing a very fast job.
Re: Latest beta version 1.1.0.26
While the quality is very good and the joining is perfect. However it appears that the clips have been re encoded and the time taken has been considarable.
See the results from Mediainfo:
They have clearly been re-encoded. Original is FullHD while join is 1024*768.Coral wrote:However it appears that the clips have been re encoded and the time taken has been considarable.
Hello Coral,
Please post your custom profile and log file...
regards,
regards,
Hello Coral,
For your information, remux can be used only if all merged files have same properties (resolution, codec...)
Maybe all your merged .mts files doesn't match this requirement?
All merged files have been of the same properties.cedric wrote:Hello Coral,
regards,
- info.rar
- (63.02 KiB) Downloaded 534 times
Ok I checked your custom profile but... I think you missed something ![Smile :)](./images/smilies/icon_smile.gif)
You need to select the "Copied if possible, otherwize encode" item as video/audio codec.
In your custom profile you selected H264, that's why the file is reencoded.
I thought you wanted to remux some merged MTS files into only one MTS, why do you selected MKV as container?
I uploaded a screenshot to show you how your custom profile need to be filled.
OK Cedric. I missed the setting for the video codec and container. It is now working like a charm.
May I sugest to put just one setting for video, audio and subtitles, if it is not a big job.
Also, you need to check the title text. See picture.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
"May I sugest to put just one setting for video, audio and subtitles, if it is not a big job"
I don't understand what you mean...
"Also, you need to check the title text"
Already fixed for the next version...
Fixed too ![Shocked :shock:](./images/smilies/icon_eek.gif)
Put a just one button.cedric wrote:"May I sugest to put just one setting for video, audio and subtitles, if it is not a big job"
