Requet Feature:Profile selector in H264 Encoding....
DjDiabolik
Post by DjDiabolik »
I have created a profile encoding loading this file:
Code: Select all
General
Complete name                            : C:\Users\Diabolik-Win7\Desktop\Sample.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 48.0 MiB
Duration                                 : 16mn 57s
Overall bit rate mode                    : Variable
Overall bit rate                         : 396 Kbps
Encoded date                             : UTC 2014-01-02 21:19:01
Tagged date                              : UTC 2014-01-02 21:19:01
gsst                                     : 0
gstd                                     : 1017195
gssd                                     : BADC20261MH1388931097312073
gshh                                     : r1---sn-hpa7enes.googlevideo.com
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Baseline@L2.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Format settings, GOP                     : M=1, N=60
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 16mn 57s
Bit rate                                 : 297 Kbps
Maximum bit rate                         : 969 Kbps
Width                                    : 400 pixels
Height                                   : 274 pixels
Display aspect ratio                     : 3:2
Frame rate mode                          : Constant
Frame rate                               : 30.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.090
Stream size                              : 36.1 MiB (75%)
Tagged date                              : UTC 2014-01-02 21:19:06
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 16mn 57s
Bit rate mode                            : Variable
Bit rate                                 : 96.0 Kbps
Maximum bit rate                         : 103 Kbps
Channel count                            : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 KHz
Compression mode                         : Lossy
Stream size                              : 11.6 MiB (24%)
Title                                    : IsoMedia File Produced by Google, 5-11-2011
Encoded date                             : UTC 2014-01-02 21:19:04
After that i have try to convert another file to .avi.... and i have obtain this:
Code: Select all
General
Complete name                            : D:\VSOVideoConverter_Project\Output.mp4
Format                                   : MPEG-4
Codec ID                                 : isom
File size                                : 44.7 MiB
Duration                                 : 12mn 37s
Overall bit rate                         : 495 Kbps
Writing application                      : Lavf55.7.100
Video
Format                                   : AVC
Format profile                           : Main@L4.0
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 3 frames
Codec ID                                 : avc1
Duration                                 : 12mn 36s
Bit rate                                 : 359 Kbps
Width                                    : 400 pixels
Height                                   : 274 pixels
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.109
Stream size                              : 32.4 MiB (72%)
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 12mn 37s
Bit rate mode                            : Constant
Bit rate                                 : 128 Kbps
Stream size                              : 11.6 MiB (26%)
Look the MEDIAINFO it's clearly the profile encoding... using the "Format Profile" set to "MAIN@L4.0". This profile it's not supported by MOST Standalone player............... and currenlty it's not possibly to change this value manually!!
All Othervalue it's been supported..........all over MP4 i have 4 example it's setted to HIGH@L3.1...
You can add this feauture ?? Or exist a not official ways to obtain and set this (like modify manually the profile encoding 4 example)...... ?
MyMojo
Re: Requet Feature:Profile selector in H264 Encoding....
Post by MyMojo »
It's now in beta 14b. Custom Profile --> Video Track.... Check it out!
