Desktop shortcut!
saad
Desktop shortcut!
Post by saad »
Could you please provide a desktop shortcut in C:\Users\Public\Desktop instead of C:\Users\user1\Desktop.
Re: Desktop shortcut!
Did you select installation "for all users" or "for this user only" ?
saad
Post by saad »
Installation package has no option like that. I think they should add that option.
Yes, it should be there - I think it is with almost all software that I have installed.
Of course you can "fix" this now by copying that shortcut there.
saad
Post by saad »
There is no such option available in this build. I don't think that you even have tried this program. Try installing it,
You got more jokes?
I have tried multiple versions of this and all other VSO programs, I simply can't remember which ones had which options on install.
