Feature Request: Increase AAC audio bitrate to 160 kbps
TrueAudio
Post by TrueAudio »
Hi, I remember along time ago, VSO video converter only went up to 96kbps per channel for encoding/remuxing, and then 128kbps was put in. I was wondering if this can be extended (for AAC) to say, up to 160kbps (or even 224 for that matter) to have fidelity even closer to DTS-HD Master Audio.
Re: Feature Request: Increase AAC audio bitrate to 160 kbps
This depends on output format, you simply can't use more than what is allowed.
TrueAudio
Post by TrueAudio »
[quote="JJ"]This depends on output format, you simply can't use more than what is allowed.[/quote]
The output format does support it. 224 Kb/s aac is equivalent to 448 Kb/s ac3 5.1 multi-channel for example.
If I recall, one of the developpers once told me this value is a "Per" channel value.
Just like JJ explained it, you select 64kb/s, the output will have 128kb/s
