VMP never play videos at their original resolution !
minhcute
Post by minhcute »
Dear VSO team,
This is the problem that I have ever said several months ago.And till now it is still not be surmounted.That is VMP never play videos at their original resolution.It always shows them at a small and fixed resolution.
An example for you to be able to understand easily : I alternately play 2 videos with VMP.The first video has resolution 1280x720,the second video has resolution 1280x544.But VMP doesn't play them with their original resolution(1280x720 or 1280x544).It always play them with a small and fixed resolution.
Could you please surmount this problem in the next version of VMP ?
Wait for your reply
Best regards
felicia
Re: VMP never play videos at their original resolution !
Post by felicia »
A feature request has been added here: http://bugs.vso-software.fr/view.php?id=7604
minhcute
Post by minhcute »
Dear VSO team
Thanks for accepting my request.But I can't view the link you gave me because it requires me to log in.I use the Usename and Password which are used to log in this forum,but I still can't log in it :
felicia
Post by felicia »
The issue has been fixed in the version we're currently testing which will be the next release.
felicia
Post by felicia »
There's a new beta avalaible here that should fix the issue:
minhcute wrote:I can't view the link you gave me because it requires me to log in.I use the Usename and Password which are used to log in this forum
Bug site has totally different user base, so you need to register in there to have access.
