Latest beta version 1.4.0.4
Latest beta version (1.4.0.4) :
see here http://forums.vso-software.fr/latest-beta-t18294.html
Latest official (stable) version is 1.4.0.4:
http://www.vso-software.fr/products/vid ... verter.php
Video Converter - 1.4.0.4 (Released 2014-07-04) [ View Issues ]
- 0008111: [Information] v1.4.0.3 ßeta / Missing ICON in .EXE (cedric) - resolved.
Video Converter - 1.4.0.2 (Released 2014-06-17) [ View Issues ]
- 0007474: [Feature Request] add dts as and audio output (cedric) - resolved.
- 0007480: [Bug] refresh drive list does not work (cedric) - resolved.
- 0007664: [Suggestion] change time display of preview by clicking on it (cedric) - resolved.
- 0007428: [Bug] delete files before conversion - problem (cedric) - resolved.
- 0007782: [Bug] crtl A in treeview in minimal view does not work (cedric) - resolved.
- 0007694: [Bug] error with custom file conversion, and when profile reopened values are modified (cedric) - resolved.
- 0007783: [Crash] crash during conversion with custom profile (cedric) - resolved.
- 0007793: [Feature Request] add divx codec (cedric) - resolved.
- 0007832: [Bug] " Total converted files size: 0 b." false as file size is bigger than 0 (cedric) - resolved.
- 0007908: [Bug] play automatically starts when navigating tabs in advanced editing window (cedric) - resolved.
- 0007925: [Information] check to see if user gets pop up about deactivating simultaneous conversions (cedric) - resolved.
- 0007993: [Feature Request] add aspect ratio setting in custom profile editor (cedric) - resolved.
- 0008087: [Bug] Burn process doesn't start automatically after conversion (cedric) - resolved.
[13 issues]
Video Converter - 1.4.0.1 (Released 2014-06-16) [ View Issues ]
- 0008086: [Feature Request] Enable aspect ratio picker for all outputs in custom profile editor (cedric) - resolved.
- 0008085: [Feature Request] Add "Fit on destination" choice in aspect ratio picker (custom profile editor) (cedric) - resolved.
- 0008084: [Bug] Can't convert SubRip subtitles to DVD subtitle format (cedric) - resolved.
- 0008083: [Bug] "Same as source" framerate choice not used (custom profile editor) (cedric) - resolved.
- 0008075: [Feature Request] Support for subtitles animation (SSA) when source framerate is higher than output framerate (cedric) - resolved.
[6 issues]
Video Converter - 1.4.0.0 (Released 2014-06-05) [ View Issues ]
- 0008077: [Bug] Maximum bitrate usable not set for conversion (and too small output file size) (cedric) - resolved.
- 0008076: [Feature Request] Add full subtitles overlap support for Blu-ray and DVD outputs (cedric) - resolved.
- 0008074: [Feature Request] Integration of new VSO burn engine (totally rewritten) (cedric) - resolved.
- 0008073: [Bug] No audio detected in a .mp4 file (not detected in VLC too) (cedric) - resolved.
- 0008070: [Feature Request] Add an option in installer to do a "clean" installation (registry clean, old and cache files deletion) (cedric) - resolved.
[5 issues]
Thank you for your help!
[13 issues]
[6 issues]
[5 issues]
Re: Latest beta version 1.2.0.0
A very important update indeed !! Good work Cedric.
Re: Latest beta version 1.2.0.1
Dear VSO team,
When will my this request be applied to VSO Video Converter ? I hope this very much :
http://forums.vso-software.fr/can-t-edi ... 17859.html
Re: Latest beta version 1.2.0.2
same reply as before "I don't think any change soon will be done in the software for you to be able to do this."
in otherwords, not for a very long time, ... maybe before 2015 but that is not for certain.
I understand.I'm sorry.I won't repeat that question in the future.
What do you think about supporting 4K resolution (and more,such as 8K and higher (if available) ) in VSO Video Converter and ConvertXtoHD in the future ? Is this a good idea ?
Re: Latest beta version 1.2.0.6
http://forums.vso-software.fr/requet-fe ... 17768.html
Great request totally ignored................. yeah.
Re: Latest beta version 1.2.0.8
Hi Cedric,
Just a small sugestion. Can you please change the wording as shown in the attached picture ?
I think it would be more meaningful .
Hello Coral,
Sorry but we can't: we will add audio file support in Video Converter soon...
So we can't use "Video" in wording.
Re: Latest beta version 1.2.0.9
I agree working is not ideal and someone else also requested this be changed.
Any suggestions, known that it should be "video" exclusive as Cedric mentions.
"Edit" only I am afraid people will think it is to edit the name of the file.
- more options
- additional parameters
- edit streams
none of the above seem great to me
- more options
- edit streams
How about "Advanced File Editor". Or just plain Advanced Editor. Edition dose not sound right to me.
I have sugested to include the word Video because the window title is Video Editor
- editor.jpg (22.18 KiB) Viewed 27989 times
I think "Advanced edit" will be right and enough.
Re: Latest beta version 1.2.0.11
There's a little blot in the log. Double string of hardware decoding.
Hello igor_lvk,
Please recheck you log file:
[X] hardware encoding
[X] hardware decoding
Hi Sedric, didn't notice!!!! Thanks.cedric wrote:Hello igor_lvk,
Re: Latest beta version 1.2.0.13
I see that when updating my custom profiles there are now new options for H264 encoder for both profile and level. Could you please give a definition/explanation of what these options provide and how to best utilize them.?
Previous step button not working in Audio editor. Please check also Quality advisor.
thanks for reporting will be fixed in next beta
Re: Latest beta version 1.2.0.14
I like the new settings editor. It looks quite original.
It appears that the Previous and the Next buttons are not required any more.
Quality advisor still not working. There is no way I can set the video bit rate in this last version.
Also, My MKV test movie causes the converter to crash.
Re: Latest beta version 1.2.0.15
Bit rate problem fixed version 1.2.0.15. MKV again working.
Re: Latest beta version 1.2.0.16
Is there something wrong with MKV conversions ? I am getting converter freezing.
The only way to exit converter is via the Windows Task Manager > End Process
