Latest beta version 3.4.0.4
Latest beta version:
no beta, see official version below
Latest official (stable) version is 3.4.0.4:
- Blu-ray Converter: http://fr.vso-software.fr/products/blur ... verter.php
- DVD Converter : http://www.vso-software.fr/products/dvd ... verter.php
Blu-ray & DVD Converters - 3.4.0.4 (Released 2014-07-04) [ View Issues ]
- 0008110: [Feature Request] DVDConverterUltimate does not have proper product/company info in exe file properties (cedric) - resolved.
- 0008090: [Bug] Free profile... is not free at all ! (MKV-VP8) (cedric) - resolved.
Blu-ray & DVD Converters - 3.4.0.3 (Not Yet Released) [ View Issues ]
- 0007930: [Bug] a particular DVD structure not imported correctly as separate titlesets (felicia) - resolved.
Blu-ray & DVD Converters - 3.4.0.2 (Released 2014-06-17) [ View Issues ]
- 0008088: [Bug] Burn process doesn't start automatically after conversion (cedric) - resolved.
[1 issue]
Blu-ray & DVD Converters - 3.4.0.1 (Released 2014-06-16) [ View Issues ]
- 0008082: [Feature Request] Add "Fit on destination" choice in aspect ratio picker (custom profile editor) (cedric) - resolved.
- 0008081: [Feature Request] Enable aspect ratio picker for all outputs in custom profile editor (cedric) - resolved.
[3 issues]
Blu-ray & DVD Converters - 3.4.0.0 (Released 2014-06-05) [ View Issues ]
- 0008080: [Bug] Maximum bitrate usable not set for conversion (and too small output file size) (cedric) - resolved.
- 0008079: [Feature Request] Add full subtitles overlap support for Blu-ray and DVD outputs (cedric) - resolved.
- 0008078: [Feature Request] Integration of new VSO burn engine (totally rewritten) (cedric) - resolved.
- 0008069: [Feature Request] Add an option in installer to do a "clean" installation (registry clean, old and cache files deletion) (cedric) - resolved.
- 0008068: [Feature Request] Remember by language choices for audio/subtitle tracks for the next time I load a file (cedric) - resolved.
[5 issues]
Thank you for your help!
[1 issue]
[3 issues]
[5 issues]
Re: Latest beta version 3.2.0.6
I still have the problem, that "merged in video" don't work by converting into mkv.
I used fixed and own created profiles.
I use the official version: 3.2.0.6
Hello Goetschi,
Have you tried doing a fresh/clean installed as recommended via the forum rules?
Thanks for reading,
Neil M
Thanks for reading,
Neil M
Please post your log file.
I tested converting to a custom profile (mkv with merged subtitles) in 1.2.0.7 (a version not yet public) and it worked as expected.
Re: Latest beta version 3.2.0.8
With 3.2.0.6, I'm having problems with file names on output. Using Nexus 10 profile, converting blueray iso to single mp4 file, output folder method as "do not add additional path", output file name become "main feature.mp4" only instead of the usual "Star wars - main feature.mp4" as in older versions.
The project name is correct, as in "Star wars" with "use first added file name" selected in settings.
Raymond.
Raymond.
I've confirmed the problem and reported it here
http://bugs.vso-software.fr/view.php?id=7815
Re: Latest beta version 3.2.0.11
the problem is fixed in 3.2.0.11
Re: Latest beta version 3.2.0.16
Icon changed back to old kind, in the Video Converter there are no icons, ( desktop)
I only have the problem with Video Converter where no icons, no problem with Blu-ray or DVD Converter.
I don't know what you mean the "Icon changed back to old kind" can you post a screenshot please?
Re: Latest beta version 3.2.0.17
when I try to convert in mkv, the video subtitle codec choices are still not remembered in custom profile Editor.
In the "advanced edit" the subtitle will be shown, but when he converts to mkv the subtitle will not be shown in the preview.
I always becames the message "an error occured while converting ....."
- Blu-ray Converter Ultimate 3_crashlog_.20140507.161115.394.log
- (13.1 KiB) Downloaded 740 times
Hello Goetschi,
Please, can you try the last official version:
http://fr.vso-software.fr/products/vide ... verter.php
I fixed a problem in this last version and it should fix your bug.
Re: Latest beta version 3.2.0.18
Hello Cetric,
I tried it with the last official version.
Everything works fine, except "merged in video".
I don't use remux video in my "custom Profile" (see file attachment).
I can see the subtitle in the preview before I convert to mkv - but not in the converted mkv file.
Please help me.
Please help me.
There seems to be a bug with 3.2.0.* where if you convert audio to AC3 (this is the only 5.1 supported format for the Roku), it doesn't respect your bitrate choice. Every conversion I have tried with 3.2.0.18 and 3.2.0.12 has resulted in files with an audio bitrate of 160kb/sec, which is extremely low for 5.1 sound. I'm using a custom profile for this, converting audio to AC3, leaving sample rate as source, and leaving channels as source. Version 3.1.0.30 converts audio to AC3 with a proper bitrate (selecting 128/channel results in a file with 640kb/sec audio channel).
Re: Latest beta version 3.2.0.19
@Goetschi your problem should be fixed in this new beta version 3.2.0.19
I'm Sorry! No merged subtitle in converted mkv file with Version 3.2.0.19
I am so sorry about the false fix - I've informed the developers.
confirmed and reported hereArmadilloMan wrote:There seems to be a bug with 3.2.0.* where if you convert audio to AC3 (this is the only 5.1 supported format for the Roku), it doesn't respect your bitrate choice. Every conversion I have tried with 3.2.0.18 and 3.2.0.12 has resulted in files with an audio bitrate of 160kb/sec, which is extremely low for 5.1 sound. I'm using a custom profile for this, converting audio to AC3, leaving sample rate as source, and leaving channels as source. Version 3.1.0.30 converts audio to AC3 with a proper bitrate (selecting 128/channel results in a file with 640kb/sec audio channel).
http://bugs.vso-software.fr/view.php?id=8016
Re: Latest beta version 3.2.0.20
Thank you soooooooo much! It works great!
