Bug: Missing Browse Files Dialogue
skoenig1
Post by skoenig1 »
Setup
Video Converter 1.2.0.1+, W7 x64, 16 GB Ram, GTX 760 (4GB), i7-2600K
Browse files missing from Add Files menu since v1.2.0.1.
In v1.2.0.1 and v1.2.0.2 the browse files is missing. You can only drag and drop files to add them. You also get a Access violoadtion error if you use the DVD folder option and point at a folder of files. VC allows you to continue and then adds the folder of files anyway but obviously something has gone wrong.
This is problem because if you drag and drop more than 16 files Windows changes their order and you need to manually reorder them which is laborious. If you use the browse files dialogue they are added in selection order.
~Steph
Re: Bug: Missing Browse Files Dialogue
skoenig1 wrote:Setup
~Steph
It is working here in version 1.2.0.2
Thank you for your feedbacks
skoenig1
Post by skoenig1 »
Thanks Coral, I must have confused myself when I looking at the diff versions! Sorry about that.
~Steph
