Setup
Video Converter 1.2.0.1, W7 x64, 16 GB Ram, GTX 760 (4GB), i7-2600K
The encode finished ok but menu pages 6 and 7 are every short (5s) compared to the usual 30s. The meun anims work in a movie player but they only last 5 seconds... have not tried burning to a disc.
See screen shot and log file attached.
~ Steph
*update*
I filed a new bug report on the latest version because that one actually seem to crash whereas this older version seemed to finished forums.vso-software.fr/bug-dies-making-menu-t17974.html
Also it then worked when I used software decoding.
Bug: Menu Encoding Failed
- VSO Video Converter 1_mainlog_.20140323.175743.237.log
- log file
- (282.8 KiB) Downloaded 268 times
Re: Bug: Menu Encoding Failed
probably fixed in 1.2.0.4
