Setup
Video Converter 1.2.0.2, W7 x64, 16 GB Ram, GTX 760 (4GB), i7-2600K
VC Died after rendering titles trying to render the menus - it just sits there @ 0 FPS. Tried with two different encodes across a reboot just in case.
When I try to close the app I get 'invalid pointer operation'. Pretty sure a decode thread died somewhere. I am using a different set of original files this time, mainly 720p and it's possible the files have errors which normal players can survive with but something in the .
Will try again turning off h/w but wanted to post here first.
~Steph
Bug: Dies making menu
- VSO Video Converter 1_crashlog_.20140324.153738.903.log
- (299.66 KiB) Downloaded 360 times
Re: Bug: Dies making menu
Same problem with 1.2.0.3, files convert fine but menu conversion fails.
07:11:11.476 Info Menu encoding failed
07:10:54.084 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GTX 660 Ti, vendor 0x10DE (NVIDIA), device 0x1183, revision 161
^^^Repeated 13 Times in 1 second(s) 224 millisecond(s)^^^
07:10:53.919 Info Building TITLE menu
22:17:50.172 Info BD menu template: ImageWall, Designed for video clip collection
13 titles convert but menu fails.
I did the same with software decoding and h/w encoding.
It worked!
~Steph
It worked!
~Steph
Hello JJ,
I think the problem was with hardware decoding used in menu encoding.
Imagewall template must open a lot of videos in same time, and major part of graphic cards don't support that.
I disabled all hardware optimizations while encoding menus, this fix will be available in next version...
should be fixed in 1.2.0.4 already posted in forum (1st thread)
Confirmed fixed... works perfectly. Now I can have fun modding your menu templates!
Steph
Steph
thanks for confirming
