Hi, Guys V1.2.0.4 the sound events do not play the event sound when the operation has completed. If you go to settings click any of sound event play symbol next to the event symbol greys out shows trying to play but stays greyed out.
Found the same with V1.2.0.3 installed official (stable) version is 1.1.0.29 as a test and event sounds functioned.
I know sounds like a bit of a whinge and most people hate Windows system sounds but hey VSO Video Converters events sounds are useful when you are multitasking.
Edit: Same problem with the DVD/Bluray converter programs as well.
V1.2.0.4 Sound Events
Budda [sic]
From Down Under
My All-rounder Rig
CPU: I7-2600K @ 4.6 GHZ
RAM: Corsair 16 Gig DDR3 1866
HDD: 11TB
Network & BU Thecus N5550
From Down Under
My All-rounder Rig
HDD: 11TB
Re: V1.2.0.4 Sound Events
thanks it will be fixed in the next version
http://bugs.vso-software.fr/view.php?id=7756
