Why I can not choose the codec Divx to DVD Converter 3.2?
Darkbeat
Post by Darkbeat »
Hello. I'm trying DVD converter and I have successfully installed my Divx codec. When I go to rip a dvd only shows me the option Xvid. Why can not I choose Divx? When ripping the DVD in Xvid in home dvd player can not play. Thank
Re: Why I can not choose the codec Divx to DVD Converter 3.2
why do you want the divx format instead of xvid?
Darkbeat
Post by Darkbeat »
because Xvid does not play the dvd-player of my home and yes it played Divx
I'ved entered it as a feature request here
http://bugs.vso-software.fr/view.php?id=7793
Darkbeat
Post by Darkbeat »
I have purchased the divx codec and I would like to use with DVD Converter. Why I can not?
Copnm
Post by Copnm »
Hello Darkbeat,
DVD Converter uses its own internal codecs. External codecs, such as the one you're talking about, do not in any way affect the program nor can they be utilized by it.
Thanks for reading,
Neil M
FYI in the latest beta version you can choose Divx now in the custom profile editor
http://forums.vso-software.fr/latest-be ... 17957.html
