Suggestion : change default subtitle font to Calibri
minhcute
Post by minhcute »
I have a small suggestion for Video Converter.That is could you please change the default subtitle font from Arial to Calibri ?
This font type has many advantages : easy to read,.... (you can search informations about it on Google) so I think it will be very suitable for watching movie on TV with DVD/Blu-ray player.
What do you think about this suggestion ?
Re: Suggestion : change default subtitle font to Calibri
In my opinion it is best to default to a standard Windows font like Arial because it is included in all Windows versions. It is also quite readable.
minhcute
Post by minhcute »
Dear Coral,
I understand.You are right.By default,font Arial is included in all Windows version while font Calibri is not.To use this font type,the users must download it from Internet and then install it into Windows.This step is very inconvenient and wasting much time while all users always like the promptitude and the convenience.This is the biggest disadvantage when using this font type.But can't negative that this font type is easier to read than font Arial very much and I'm very interested in it.
So,dear VSO team,what is your opinion about font Calibri ?
