Copying blu ray movie.
Hope this hasn't been covered elsewhere but if it was I apologize. I'm a goldmember and now a senior so my concentration isn't as good. Can I copy a blu ray movie that is over 40 gigs and shrink it down to a 25 gig blank?
Re: Copying blu ray movie.
Yes you can.
I suggest you do that with Video Converter.
Load the Blu-ray, in the settings, make sure you have target size under blu-ray selected for BD 25
Then remove the audio and video streams you don't want. Select the conversion profile HD structures Blu-ray 1080p
Thanks Claire but would that be blu ray convertor or dvd convertor?
Oh I see video convertor. Thanks
One more question on that, " make sure target size under blu-ray selected for BD 25" I don't see that setting.
I see the problem that I had was I was using version1.1.0.20. When I clicked update now it said I had latest version. I went to main page and got the latest. I think all is well now.
oh ok great
