Settings for blu ray burning
doer
Post by doer »
When I copied a movie with 40 gigs to blank bd disk it burned but only filled 3 gigs. How do I shrink it to do it over the full 25 gigs that the disk holds? Thanks
Re: Settings for blu ray burning
It is not that simple.
Check this sub-forum for guides.
http://forums.vso-software.fr/convertxt ... s-f23.html
Look for tips on video compression, converting, burning and how to post log.
