Hello:
I am trying to download a video from this source: See Top of Log file attached.
VSO Downloader recognizes the video but does not download, and gives me a "Download Error" after about 1 - 2 minutes...and shows a red download bar, with the video name above it. When I look in the download folder, the video file name is there but has a size of zero.
I have tried using both Network Drivers built into VSO Downloader, but with the same result.
I have attached the log file, and was wondering if someone could help?
Thanks in advance,
Nanook1963
VSO Downloader 4.0.0.19 - Download Error
- downloader_log.20140524.130627.573.log
- Log File
- (10.46 KiB) Downloaded 508 times
Re: VSO Downloader 4.0.0.19 - Download Error
please provide an url to reproduce the issue.
Benjamin:
http://www.byutv.org/watch/c3bae702-d31 ... #!listMain
(The link is also listed on the top line of my log file).
Nanook1963
Nanook1963
I can get 60% of the stream then a timeout occured that cannot be restarted, you can try to restart the download but the server seems to be overloaded and do not support standard comands.
Weird.
I can't get anything to download.
Do you think there will be a solution to this in a future version of VSO Downloader?
can you read the media without problem?
I can view the media/stream in IE 11 with no problem but cannot download any part of the stream successfully in VSO Downloader. I get no green bar...only red bar when it fails.
When I look in download directory when the download fails, I see a correctly named .flv file, but it has a size of 0 bytes.
Nanook1963
Nanook1963
Can you send me a report using our support tool:
http://download.vso-software.fr/vsorep.exe
