Fuzzy videos
Pilgrim731
Fuzzy videos
Post by Pilgrim731 »
Downloaded the current media player and all the videos I tried to play are very low resolution and I found no place to change the resolution. Back to VLC. Also prefer VLC for volume control using the mouse wheel.
minhcute
Re: Fuzzy videos
Post by minhcute »
Hi Pilgrim731,
I have ever mentioned about this matter to VSO team for 3 months ago.You can see my that topic at here :
http://forums.vso-software.fr/vmp-never ... 17889.html
And since version 1.4.1.473,this matter has been surmounted as an additional feature.That is : If you want to play any video in its original resolution,you can do as guide below (please view 3 pictures below : Step 1.jpg,Step 2.jpg and Step 3.jpg).And 2 pictures below : An example result 1.jpg and An example result 2.jpg is a result which I tested on my computer.
Hope these things will be useful for you
Best regards
Step 1
Step 1
Step 2
Step 2
Step 3
Step 3
An example result 1
An example result 1
An example result 2
An example result 2
Re: Fuzzy videos
thanks very much minhcute!
