Feature Request: H264 Quality Presets, Reference Frames etc.
cribber
Post by cribber »
Hi, is there any chance of having quality presets for H264 ? Once I convert a movie into MKV H264 the codec information says 0 Reference Frames. Is this why the encoder is fast and produces massive file sizes ? If we had reference frames etc. it would seriously reduce the file size and have better quality. It's nice to have the option.
cribber
Re: Feature Request: H264 Quality Presets, Reference Frames
Post by cribber »
Is this possible to have reference frames etc. or quality Presets for H264 to make the file sizes smaller a better quality or would this conflict with your current conversion engine ?
Will be added in future versions (but not the next...)
cribber
Post by cribber »
Cheers.
cribber
Post by cribber »
Any progress on this ??????
MyMojo
Post by MyMojo »
This morning Cedric made a post here, http://forums.vso-software.fr/doing-som ... 67-20.html that he might be heading there with version .13 but I'm at work and haven't downloaded it yet. Have you had a chance to see what he's referring too?
Hi all,
Please, take a look on the last beta version (1.4.0.14) : http://forums.vso-software.fr/post90200.html#p90200
MyMojo
Post by MyMojo »
WHOOOOOO HOOOOOOOO! And the crowd goes wild!!!
NOW, we're cooking with gas!!!!!!! Man I can't wait to play with these settings.... Awesome!
Cedric, you're the man!
Thanks!!
It's located at Custom Profile --> Video Track.... Check it out!
